Hi Guys,
I want to make a Nextcloud installation accessible from the outside. I succeeded, but I just can't get a valid certificate. I work with a VM in a Proxmox environment and have already tried a variety of ways. Without success. Now I have an installation with nextcloudpi on my server, but I have the problem below with all installations. My firewall is Ubiquiti's UDM and ports 80 + 443 are forwarded to the VM. I am grateful for any information.
Thank you.
Malte
My domain is: maltecloud.de
I ran this command: Click on Apply Button in nextcloudpi GUI for "Automatic signed SSL certificates"
[ letsencrypt ] (Fri May 28 12:49:36 CEST 2021)
http-01 challenge for maltecloud.de
Using the webroot path /var/www/nextcloud for all unmatched domains.
Failed authorization procedure. maltecloud.de (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://maltecloud.de/.well-known/acme-challenge/2fn7xtVRUK_VeOJiS8WroKNtDOk27SRT5zk0g0NKziE: Timeout during connect (likely firewall problem)
Domain: maltecloud.de
Type: connection
Detail: Fetching
My web server is (include version): Apache/2.4.38 (Debian)
The operating system my web server runs on is (include version): Debian Buster 10.9 in Proxmox VM
My hosting provider, if applicable, is: selfhost.de
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): nextcloudpi web gui
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.31.0
