Help: Timeout during connect (likely firewall problem)
My domain is: cloud.nikology.dev
I ran this command: Used ncp config tool
[ letsencrypt ] (Sun 27 Aug 23:01:22 BST 2023)
Requesting a certificate for cloud.nikology.dev
http-01 challenge for cloud.nikology.dev
Using the webroot path /var/www/nextcloud for all unmatched domains.
Challenge failed for domain cloud.nikology.dev
Domain: cloud.nikology.dev
Type: connection
The operating system my web server runs on is (include version): nextcloudpi
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): NextcloudPi v1.52.4
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot v1.12.0
P.S. Kindof new to this stuff.
Hello @Nikology, welcome to the Let's Encrypt community. :slightly_smiling_face:
Using the online tool Let's Debug yields these results https://letsdebug.net/cloud.nikology.dev/1593746
ReservedAddress
Fatal
A private, inaccessible, IANA/IETF-reserved IP address was found for cloud.nikology.dev. Let's Encrypt will always fail HTTP validation for any domain that is pointing to an address that is not routable on the internet. You should either remove this address and replace it with a public one or use the DNS validation method instead.
192.168.86.42
Here you can read about Reserved IP addresses - Wikipedia
No worries I figured it out. Thanks for directing me to that website.
