NextCloud Timeout during connect (likely firewall problem)
My domain is: nextcloud.echogroupinc.com
Detail: During secondary validation: 70.171.148.25: Fetching http://nextcloud.echogroupinc.com/.well-known/acme-challenge/--vfXgNo7l0V63-4nbPnLfVRxGbHdww0e0YySEepWjk: Timeout during connect (likely firewall problem)
To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address. Additionally, please check that your computer has a publicly routable IP address and that no firewalls are preventing the server from communicating with the client. If you're using the webroot plugin, you should also verify that you are serving files from the webroot path you provided.
2024-04-29 12:37:56,247:DEBUG:certbot.error_handler:Encountered exception:
File "/snap/nextcloud/41512/lib/python2.7/site-packages/certbot/auth_handler.py", line 90, in handle_authorizations
File "/snap/nextcloud/41512/lib/python2.7/site-packages/certbot/auth_handler.py", line 154, in _poll_authorizations
AuthorizationError: Some challenges have failed.
Description: Place files in webroot directory
Entry point: webroot = certbot.plugins.webroot:Authenticator
Initialized: <certbot.plugins.webroot.Authenticator object at 0x7f78dde8d0d0>
Prep: True
2024-04-29 12:56:55,509:DEBUG:certbot.plugins.selection:Selected authenticator <certbot.plugins.webroot.Authenticator object at 0x7f78dde8d0d0> and installer None
2024-04-29 12:56:55,509:INFO:certbot.plugins.selection:Plugins selected: Authenticator webroot, Installer None
2024-04-29 12:56:55,513:DEBUG:certbot.main:Picked account: <Account(RegistrationResource(body=Registration(status=None, terms_of_service_agreed=None, agreement=None, only_return_existing=None, contact=(), key=None, external_account_binding=None), uri=u'https://acme-v02.api.letsencrypt.org/acme/acct/390151350', new_authzr_uri=None, terms_of_service=None), 4db2ae5f7ffb5a2048b4f46390bc75f7, Meta(creation_host=u'nextcloud', creation_dt=datetime.datetime(2022, 2, 1, 14, 44, 18, tzinfo=)))>
2024-04-29 12:56:55,514:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2024-04-29 12:56:55,517:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2024-04-29 12:56:55,665:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 747
2024-04-29 12:56:55,666:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Mon, 29 Apr 2024 17:56:55 GMT
Content-Length: 747
X-Frame-Options: DENY
My web server is (include version): nextcloud 27.1.8
Ubuntu 22.04.4 LTS
Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Certbot 1.21.0
Fatal: Check of /.well-known/acme-challenge/random-filename has a http status 401 / 403 Not Allowed / Forbidden. A http status 404 - Not Found - is expected. Creating a Letsencrypt certificate via http-01 challenge may not work.
Hello @Chuck3, welcome to the Let's Encrypt community. :slightly_smiling_face:
Using the online tool Let's Debug yields these results
https://letsdebug.net/nextcloud.echogroupinc.com/1913365
ANotWorking
ERROR
nextcloud.echogroupinc.com has an A (IPv4) record (70.171.148.25) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
A timeout was experienced while communicating with nextcloud.echogroupinc.com/70.171.148.25: Get "http://nextcloud.echogroupinc.com/.well-known/acme-challenge/letsdebug-test": context deadline exceeded
Trace:
@0ms: Making a request to http://nextcloud.echogroupinc.com/.well-known/acme-challenge/letsdebug-test (using initial IP 70.171.148.25)
@0ms: Dialing 70.171.148.25
@10000ms: Experienced error: context deadline exceeded
Yet from my location seem ok
$ nmap -Pn -p80,443 nextcloud.echogroupinc.com                                                            Starting Nmap 7.80 ( https://nmap.org ) at 2024-04-29 13:05 PDT
Nmap scan report for nextcloud.echogroupinc.com (70.171.148.25)
Host is up (0.070s latency).
rDNS record for 70.171.148.25: wsip-70-171-148-25.om.om.cox.net
PORT    STATE SERVICE
80/tcp  open  http
443/tcp open  https
Nmap done: 1 IP address (1 host up) scanned in 0.17 seconds
$ curl -i  http://nextcloud.echogroupinc.com/.well-known/acme-challenge/sometestfile                      HTTP/1.1 403 Forbidden
Date: Mon, 29 Apr 2024 20:05:24 GMT
Server: Apache
Content-Length: 199
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>403 Forbidden</title>
</head><body>
<h1>Forbidden</h1>
<p>You don't have permission to access this resource.</p>
</body></html>
From around the world I see mostly "Connection timed out" here Permanent link to this check report
Do you have some geo blocking going (or possibly your ISP or Country)?
What Country's will need to be unblocked? We have 93 blocked.
That is hard to say
What IP addresses does Let’s Encrypt use to validate my web server?
Let’s Encrypt does not publish a list of IP addresses we use to validate,
and these IP addresses may change at any time.
Let's Encrypt uses Multi-Perspective Validation Improves Domain Validation Security - Let's Encrypt
Probably don't want to do that.
You may want to consider splitting your extremely protected systems from the simple ACME client(s).
From the post that @Bruce5051 linked earlier the two new countries are Sweden and Singapore. These can change at anytime
