nextcloud.con20.xyz
certbot --nginx -d nextcloud.con20.xyz
Requesting a certificate for nextcloud.con20.xyz
Domain: nextcloud.con20.xyz
Type: connection
Detail: 80.162.33.206: Fetching http://nextcloud.con20.xyz/.well-known/acme-challenge/gAf26LWGLz30ikPkmN-dN4Vu3bsGWVpwbIBs8OsqBu4: Timeout during connect (likely a firewall problem)
nginx-1.30.0
FreeBSD (TrueNAS Core Jail)
Yes
TrueNAS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.30.0
