My domain is: empati.ga
I ran this command: sudo certbot --nginx -d empati.ga
It produced this output: Timeout during connect (likely firewall problem)
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: aws
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
I can confirm that there is only a timeout when connecting to empati.ga on port 80. Please open the port in your firewall or portmap the port in your (NAT) router, whatever is applicable.
Thank you for your reply now i opened the ports both 80 and 443 can you check again because i cant get ssl now because of hourly limit. and where can i check this
Port 80 is open, yes.
thanks for your help its done
