My domain is:test.munkham.cfd
I ran this command:sudo certbot certonly --standalone --preferred-challenges http --agree-tos --email netkid64@gmail.com -d test.munkham.cfd
i dont know how to check the port in firewall and i dont know the command i am just copy and paste the command so if you can guide me to check the port if it is open and the solution to my problem
For in the future, may I make a recommendation? It seems there were just 5 minutes between @9peppe s post and your next post requesting for more guidance.
I'm pretty sure you didn't scoured the entire web looking for a possible answer in that limited amount of time. I'd like to suggest an attitude more revolving on trying to sort something out yourself properly before asking others for help. It might take some time, effort and possibly frustration, but learning to be more self-taught will in the end help you more.
Especially as this is a Let's Encrypt Community and not a generic "How does my firewall work" Community
