My domain is: sso.smartidentity.nicotechnologies.com
I ran this command:sudo certbot --nginx -d sso.smartidentity.nicotechnologies.com
It produced this output: Domain: sso.smartidentity.nicotechnologies.com
Type: connection
Detail: Fetching http://sso.smartidentity.nicotechnologies.com/.well-known/acme-challenge/gmy-f9EErY2ZZyLuIaIJebpRI0Xl1UhoBU876QA2VCU: Timeout during connec>
To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP addre>
2
The operating system my web server runs on is (include version): ubunut 20
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.40.0
Hi @sekulu,
It looks like some part of your network doesn't permit incoming connections from the rest of the Internet. In order to complete this verification, you have to be able to receive incoming connections on port 80, which currently seems to be blocked by a firewall or something.
the problem was with my AAAA records. this has been resolved
