systems.social
I ran this command (I tried both):
sudo certbot renew
sudo certbot --nginx -d systems.social
aving debug log to /var/log/letsencrypt/letsencrypt.log
An RSA certificate named systems.social already exists. Do you want to update
its key type to ECDSA?
(U)pdate key type/(K)eep existing key type: U
Renewing an existing certificate for systems.social
Domain: systems.social
Type: connection
Detail: 178.21.117.252: Fetching http://systems.social/.well-known/acme-challenge/jXthMPUSgWQhpspLs51Gs8oMOrF4a7XEYZBL6w9HiG0: Timeout during connect (likely firewall problem)
nginx/1.18.0
Debian GNU/Linux 11
Yes
No
or certbot-auto --version
if you're using Certbot):
Certbot 2.1.0.dev0
I am not able to renew my certificate for my self hosted mastodon instance. I host mastodon in a seperate docker container and use nginx to forward port 443 to the docker container.
I also host other containers on the same VPS behind nginx as a proxy. I do not use ipv6 and have one ip address.
I have tried removing certbot and the nginx validation, and tried reinstallation.
This is the port 80 section in my nginx configuration:
listen 80;
listen [::]:80 ipv6only=on;
server_name systems.social;
root /var/www/html;
location ~ ^/.well-known/acme-challenge/*{
root /var/www/cert-validation/;
#location /.well-known/acme-challenge/ { allow all; }
location / { return 301 https://$host$request_uri; }
What could be my next step?
