The problem with issuing a certificate
Hello! I have a problem with issuing a certificate. I am trying to issue a certificate, but I keep getting the following error
And so it is with all the domains that I have
Hello, and welcome to the community.
You should really try and answer these questions.
If you don't understand some, ask.
I see from your post history that you might be in Russia. Check that your domain doesn't belong to an entity sanctioned by the US government. You won't be able to issue certificates if that's the case:
https://sanctionssearch.ofac.treas.gov/
I use win-acme.v2.1.20. to issue certificates. Doing N: Create certificate (default settings) . After I choose my domain vertex15.ru and I get the above error. Windows server 2016 datacenter operating system. Certbot is not used. I am also on the territory of Russia. I have 290 domain names, not one of them, I can't update the certificate or issue a new one
But I can issue certificates using the following program
Is the issue with one specific domain name or all of them?
We need to see the actual error, and your teminal output isn't saying much. You should find the option to make your client speak more ("verbose" or something like that)
The problem is with all domains. The terminal does not issue any specific error, all that it sends is "Failed to create a certificate". This has never happened before
And when I try to update the certificate, I get the following
And I can't figure out what the problem is because there is no definite error
"Failed to create order" is a very specific error and can depend on several things:
  • can you reach Let's Encrypt servers?
  • are you ratelimited? (maybe the other app is using a different ACME account)
  • are you banned because of sanctions?
We need to know more. You can wait, or you should investigate. Check if you have failed renewals in your logs, before it started saying "Failed to create order"
Maybe try using --verbose on the command for more details
