The manual plugin is not working; The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.',)
I get the HTTPS by opening 80 port in my ec2 instance. And running this command:
sudo certbot --nginx -d api.geeknoon.com
this add some code in my nginx file:
sudo cat /etc/nginx/sites-available/geeknoon_server
    server_name api.geeknoon.com;
    location = /favicon.ico { access_log off; log_not_found off ; }
    location /static/ { root /home/ubuntu/geeknoon_server; }
        include proxy_params;
        proxy_pass http://unix:/home/ubuntu/geeknoon_server/geeknoon_server.sock;
    ssl_certificate /etc/letsencrypt/live/api.geeknoon.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/api.geeknoon.com/privkey.pem; # managed by Certbot
    if ($host = api.geeknoon.com) {
    } # managed by Certbot
    listen 80;
and when i run thus: sudo certbot renew --dry-run
i get this error:
Processing /etc/letsencrypt/renewal/api.geeknoon.com.conf
Could not choose appropriate plugin: The manual plugin is not working; there may be problems with your existing
configuration.
Attempting to renew cert (api.geeknoon.com) from /etc/letsencrypt/renewal/api.geeknoon.com.conf produced an une
xpected error: The manual plugin is not working; there may be problems with your existing configuration.
nual plugin non-interactively.',). Skipping.
Processing /etc/letsencrypt/renewal/geeknoon.com.conf
configuration.
Attempting to renew cert (geeknoon.com) from /etc/letsencrypt/renewal/geeknoon.com.conf produced an unexpected
/etc/letsencrypt/live/api.geeknoon.com/fullchain.pem (failure)
/etc/letsencrypt/live/geeknoon.com/fullchain.pem (failure)
**          (The test certificates below have not been saved.)
**          (The test certificates above have not been saved.)
2 renew failure(s), 0 parse failure(s)
I'm guessing this is not the first time you've used certbot to get a certificate for that hostname. Certbot doesn't just come up with the manual plugin out of nothing, I'm pretty sure you've used it in the past
Perhaps you could try combining both directives, i.e. --nginx and --dryrun to simulate the renewal without the manual plugin but with the nginx plugin. I'm not sure if the dry run will overwrite the renewal configuration file though for future renewals.
Edit:Just tested here with the apache plugin: it does manage to do the challenge through the apache authenticator, but the configuration doesn't get updated.
So you can test the nginx plugin with --dry-run --nginx, but you'll have to update your renewal configuration file in another way. Three options:
  • wait until renewal is close (Let's Encrypt advices to renew 60 days after issuance, i.e., 30 days before the expiration date of the certificate) and renew with certbot renew --nginx;
  • force renewal with the nginx plugin by adding --force-renewal just once. Note: this adds a little bit of strain on the Let's Encrypt resources if many people would just force renewals even if it isn't really necessary. Just one certificate out of thousands wouldn't make a difference though.
  • manually edit the renewal configuration file yourself to change authenticator = manual to authenticator = nginx.
