The manual plugin is not working; there may be problems with your existing configuration
prove.redball.rocks
certbot renew
Processing /etc/letsencrypt/renewal/prove.redball.rocks.conf
Could not choose appropriate plugin: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.',)
Attempting to renew cert (prove.redball.rocks) from /etc/letsencrypt/renewal/prove.redball.rocks.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.',). Skipping.
/etc/letsencrypt/live/prove.redball.rocks/fullchain.pem (failure)
root@ip-172-31-20-158:/home/ubuntu# nginx -v
nginx version: nginx/1.14.0 (Ubuntu)
root@ip-172-31-20-158:/home/ubuntu# uname -a
Linux ip-172-31-20-158 4.15.0-1063-aws #67-Ubuntu SMP Mon Mar 2 07:24:29 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
AWS
YES
NO
root@ip-172-31-20-158:/home/ubuntu# certbot --version
certbot 0.31.0
Question: Is it enough to have nginx running and port 80 open for this to work? (do I even need to have nginx running?)
If you want to use your nginx running on port 80 your config is wrong, use this command:
certbot renew --nginx --preferred-challenges=http
I don't really care how it works, I just need it to work somehow.
The best would be without nginx, just with port 80 open.
I ran your command with port 80 open and nginx running but it didn't work:
root@ip-172-31-20-158:/home/ubuntu# certbot renew --nginx --preferred-challenge http
Could not choose appropriate plugin: The requested nginx plugin does not appear to be installed
Attempting to renew cert (prove.redball.rocks) from /etc/letsencrypt/renewal/prove.redball.rocks.conf produced an unexpected error: The requested nginx plugin does not appear to be installed. Skipping.
These are choices only you can make. If your port 80 is free, you can use --standalone instead of --nginx
That worked. I sense you are very great genius.
