Temporary bypass of limits
Hello,
I had (and still have) problems with setting up a full automatized renewal with importing in terminalservers. Now i reached the limit (too many certificates already issued). Is it possible to request a bypass or raising of the limits temporarily somewhere?
Thanks
In short, no, sorry.
You can use one of the existing certificates you have of course, which are still valid.
For testing, you should really use the staging server - as this doesn’t have the same limnits.
Ok thanks,
how can i use it?
That depends exactly what client you are using - then general details are at https://letsencrypt.org/docs/staging-environment/
essentially you change the URL your client is connecting to to obtain certificates ( for certbot you can use the --test-cert flag )
