SSLLABS says certificate is untrusted
https://www.ssllabs.com/ssltest/analyze.html?d=magnesium.crosswell.holtain.net
Trusted No NOT TRUSTED (Why?)
Seems to be issues with the generated chain.crt
getssl magnesium.crosswell.holtain.net
Registering account
Verify each domain
Verifying magnesium.crosswell.holtain.net
magnesium.crosswell.holtain.net is already validated
Verifying magnesium2.crosswell.holtain.net
magnesium2.crosswell.holtain.net is already validated
Verification completed, obtaining certificate.
Requesting Finalize Link
Requesting Order Link
Requesting certificate
Certificate saved in /root/.getssl/magnesium.crosswell.holtain.net/magnesium.crosswell.holtain.net.crt
reloading SSL services
Stopping httpd: [ OK ]
Starting httpd: [ OK ]
magnesium.crosswell.holtain.net - rsa certificate installed OK on server
certificate obtained for magnesium.crosswell.holtain.net
Server version: Apache/2.2.15 (Unix)
CentOS 6
Yes
No
getssl V2.45
getssl has a quirk that by default get its certificate from testing server, which has lax rate limit but is not trusted by browser.
you will need to edit ~/.getssl/config.cfg to change server to production. it will have relevent option commented at the start of the file
I'd forgotten that quirk!
Comment out the first server listed and uncomment the second and all is well
# The staging server is best for testing (hence set as default)
CA="https://acme-staging-v02.api.letsencrypt.org"
# This server issues full certificates, however has rate limits
#CA="https://acme-v02.api.letsencrypt.org"
