Cert not trusted
I have not had to setup a SSL cert manually before and I am stumbling through the process. My cert seems to be installed and working but my site is showing as untrusted. I have looked at multiple sources to find a solution but have not found one that resolves my issue.
My domain is: themagnoliadifference.com
I ran this command: certbot apache -d
The operating system my web server runs on is (include version): Cent 7
My hosting provider, if applicable, is: Hostinger VPS
That's probably not the command you actually ran, as that would give an error.
We really need the actual output of certbot. If you don't have the terminal output any longer, you can find the logs in /var/log/letsencrypt/.
Also funny thing:
themagnoliadifference.com. 3600 IN A 83.136.219.183
Where 83.136.219.183 is indeed a Hostinger IP address.
While:
www.themagnoliadifference.com. 3600 IN CNAME ghs.googlehosted.com.
Which of course resolves to a Google hosting IP address..
So your apex domain is hosted somewhere else than your www subdomain? Weeeiiird..
Hi @bpatton
that's
an incomplete command.
What says
certbot certificates
[root@themagnoliadifference ~]# certbot certificates
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -`Preformatted text`
Found the following certs:
  Certificate Name: themagnoliadifference.com
    Serial Number: 307d25d0a3f227cf5bf2d93221e58397e4d
    Key Type: RSA
    Domains: themagnoliadifference.com
    Expiry Date: 2021-04-30 22:58:43+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/themagnoliadifference.com/fullchain.                                          pem
    Private Key Path: /etc/letsencrypt/live/themagnoliadifference.com/privkey.pe                                          m
Yes. I purchased the domain from Google and resolve to my VPS on Hostinger.
So you have created a valid certificate.
Try
certbot --reinstall -d themagnoliadifference.com -i apache
See output below. I rebooted server and I am still receiving a untrusted site warning in Chrome.
[root@themagnoliadifference ~]# certbot --reinstall -d themagnoliadifference.com -i apache
1: Apache Web Server plugin (apache)
2: Spin up a temporary webserver (standalone)
3: Place files in webroot directory (webroot)
Select the appropriate number [1-3] then [enter] (press 'c' to cancel): 1
Cert not yet due for renewal
Deploying Certificate to VirtualHost /etc/httpd/conf.d/themagnoliadifference.com-le-ssl.conf
Enhancement redirect was already set.
Congratulations! You have successfully enabled https://themagnoliadifference.com
So your apache configuration is buggy, there is again the self signed.
What says
apachectl -S
[root@themagnoliadifference ~]# apachectl -S
VirtualHost configuration:
*:443 is a NameVirtualHost
default server themagnoliadifference.com (/etc/httpd/conf.d/ssl.conf:56)
port 443 namevhost themagnoliadifference.com (/etc/httpd/conf.d/ssl.conf:56)
port 443 namevhost themagnoliadifference.com (/etc/httpd/conf.d/themagnoliadifference.com-le-ssl.conf:2)
alias themagnoliadifference.com
*:80 themagnoliadifference.com (/etc/httpd/conf.d/themagnoliadifference.com.conf:1)
ServerRoot: "/etc/httpd"
Main ErrorLog: "/etc/httpd/logs/error_log"
Mutex authn-socache: using_defaults
Mutex default: dir="/run/httpd/" mechanism=default
Mutex fcgid-pipe: using_defaults
Mutex authdigest-opaque: using_defaults
Mutex proxy-balancer-shm: using_defaults
Mutex authdigest-client: using_defaults
Mutex fcgid-proctbl: using_defaults
Mutex proxy: using_defaults
PidFile: "/run/httpd/httpd.pid"
Define: _RH_HAS_HTTPPROTOCOLOPTIONS
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="apache" id=48
Group: name="apache" id=48
There is your buggy configuration.
Two port 443 vHosts with the same domain name. Merge both in one, remove the other.
