Certbot Problem
My domain is: offclkaan.de
I ran this command: certbot --apache
My web server is (include version): apache2
The operating system my web server runs on is (include version): Debian 12
My hosting provider, if applicable, is: FastLayer
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): nothing
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.1.0
2024-08-11 20:06:21,891:DEBUG:certbot._internal.main:certbot version: 2.1.0
2024-08-11 20:06:21,891:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
2024-08-11 20:06:21,891:DEBUG:certbot._internal.main:Arguments: ['--apache']
2024-08-11 20:06:21,892:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2024-08-11 20:06:21,896:DEBUG:certbot._internal.log:Root logging level set at 30
2024-08-11 20:06:21,896:DEBUG:certbot._internal.plugins.selection:Requested authenticator apache and installer apache
2024-08-11 20:06:21,929:DEBUG:certbot_apache._internal.configurator:Apache version is 2.4.61
2024-08-11 20:06:22,024:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * apache
Description: Apache Web Server plugin
Interfaces: Authenticator, Installer, Plugin
Entry point: apache = certbot_apache._internal.entrypoint:ENTRYPOINT
Initialized: <certbot_apache._internal.override_debian.DebianConfigurator object at 0x7fb3d43611d0>
Prep: True
2024-08-11 20:06:22,025:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot_apache._internal.override_debian.DebianConfigurator object at 0x7fb3d43611d0> and installer <certbot_apache._internal.override_debian.DebianConfigurator object at 0x7fb3d43611d0>
2024-08-11 20:06:22,025:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator apache, Installer apache
2024-08-11 20:06:41,528:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2024-08-11 20:06:41,529:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2024-08-11 20:06:42,000:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 746
2024-08-11 20:06:42,001:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 11 Aug 2024 18:06:41 GMT
Content-Length: 746
X-Frame-Options: DENY
  "14r5swto87M": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
  "meta": {
    "caaIdentities": [
      "letsencrypt.org"
    "termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.4-April-3-2024.pdf",
  "renewalInfo": "https://acme-v02.api.letsencrypt.org/draft-ietf-acme-ari-03/renewalInfo",
2024-08-11 20:06:44,028:DEBUG:acme.client:Requesting fresh nonce
2024-08-11 20:06:44,028:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2024-08-11 20:06:44,183:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2024-08-11 20:06:44,183:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 11 Aug 2024 18:06:44 GMT
Replay-Nonce: cgBcsAuLqLSz3znT211m29tOC2YfZd0jbz7_XTr6nQgRDloXyyg
2024-08-11 20:06:44,183:DEBUG:acme.client:Storing nonce: cgBcsAuLqLSz3znT211m29tOC2YfZd0jbz7_XTr6nQgRDloXyyg
2024-08-11 20:06:44,183:DEBUG:acme.client:JWS payload:
b'{\n  "contact": [\n    "mailto:mail@fastlayer.eu"\n  ],\n  "termsOfServiceAgreed": true\n}'
2024-08-11 20:06:44,186:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-acct:
  "protected": "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",
  "signature": "JjIrjKUG23l_OCn6f9OroUhQEnvgqWMYV_PyvcaKoEyg2UVlPsaVj0h2zg7eXQpOnroe4c1hQCBdgxMQCji5CMMNRJXFt3c-YiekksLVpymci-K8hp3_qUOaD0bgaFtwkxQROSvev19fJ1_6oTazBJAhpJXxgxVR4bh_oR89EMpryv3c1zDWVuY4chdXOfn1EJhUib_MnGS5TbCWgZBSSgCQmzgCYNROA-SpfeVy3DypEbK3zAsA7GagbYiDDHhHHq1lAuXGg4QjS21_y_JZbZBJlx2Jrt1G8XhsGDLiSVToEwej4y1XNSNyaIBjS2wNLpYvsfsaCtI6qrBoxDYPGg",
  "payload": "ewogICJjb250YWN0IjogWwogICAgIm1haWx0bzptYWlsQGZhc3RsYXllci5ldSIKICBdLAogICJ0ZXJtc09mU2VydmljZUFncmVlZCI6IHRydWUKfQ"
2024-08-11 20:06:44,355:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-acct HTTP/1.1" 201 561
2024-08-11 20:06:44,356:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Content-Length: 561
Boulder-Requester: 1885871776
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index", <https://letsencrypt.org/documents/LE-SA-v1.4-April-3-2024.pdf>;rel="terms-of-service"
Location: https://acme-v02.api.letsencrypt.org/acme/acct/1885871776
Replay-Nonce: cgBcsAuLa6PJtaLlT8i6bwLji_f1k2zGwD7C6ArZYAUgCHsKPBQ
  "key": {
    "kty": "RSA",
    "n": "oniGBnMKfpTTY4Ni15iyJneyAB7Ff5pGYXD_4A1bKCY4I-DU4aoPc7V4FwkNSgi6r7L-OeX-aSjSlC70ykoJtMWzPg3D6rUcPjc1GNuk309vP0SeZjLAnqInGoFIdeOsZ21D1mC9BKWrJ0PXOdvEly5Ab0eSZaJKsK5ZQC1OujOmthDX2axJJLFhpJo1kDQWhqWFFWpMV3L1z2GgD34wQHn1SxcR4wAZy_29koD1jNZsJofsLdsxF9TjZogbEs-Mh7_EBBHvHQ61WejhemuRVe6OqgNiTJjZiLQU1Q2RpNDPNEcAn2r8zIk1Nz3IDuKvv_dNLXNVtLDV760YGguNJQ",
    "e": "AQAB"
  "contact": [
  "initialIp": "185.155.223.83",
  "createdAt": "2024-08-11T18:06:44.260607733Z",
  "status": "valid"
2024-08-11 20:06:44,356:DEBUG:acme.client:Storing nonce: cgBcsAuLa6PJtaLlT8i6bwLji_f1k2zGwD7C6ArZYAUgCHsKPBQ
2024-08-11 20:06:46,720:DEBUG:certbot._internal.display.obj:Notifying user: Account registered.
2024-08-11 20:06:46,720:DEBUG:certbot._internal.main:Picked account: <Account(RegistrationResource(body=Registration(key=JWKRSA(key=<ComparableRSAKey(<cryptography.hazmat.backends.openssl.rsa._RSAPublicKey object at 0x7fb3d0152190>)>), contact=('mailto:mail@fastlayer.eu',), agreement=None, status='valid', terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letsencrypt.org/acme/acct/1885871776', new_authzr_uri=None, terms_of_service='https://letsencrypt.org/documents/LE-SA-v1.4-April-3-2024.pdf'), 83b783c1df78fc63c0d2bd7960fdd9b3, Meta(creation_dt=datetime.datetime(2024, 8, 11, 18, 6, 44, tzinfo=<UTC>), creation_host='vault.offclkaan.de', register_to_eff='mail@fastlayer.eu'))>
2024-08-11 20:06:49,336:DEBUG:certbot._internal.display.obj:Notifying user: Requesting a certificate for vault.offclkaan.de
2024-08-11 20:06:49,338:DEBUG:certbot.crypto_util:Generating ECDSA key (2048 bits): /etc/letsencrypt/keys/0000_key-certbot.pem
2024-08-11 20:06:49,339:DEBUG:certbot.crypto_util:Creating CSR: /etc/letsencrypt/csr/0000_csr-certbot.pem
2024-08-11 20:06:49,340:DEBUG:acme.client:JWS payload:
b'{\n  "identifiers": [\n    {\n      "type": "dns",\n      "value": "vault.offclkaan.de"\n    }\n  ]\n}'
2024-08-11 20:06:49,341:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTg4NTg3MTc3NiIsICJub25jZSI6ICJjZ0Jjc0F1TGE2UEp0YUxsVDhpNmJ3TGppX2YxazJ6R3dEN0M2QXJaWUFVZ0NIc0tQQlEiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL25ldy1vcmRlciJ9",
  "signature": "crUq-H9U4R_-Y9azzRutNwxHpXBFHQ8lmutg5QBIjEV90npUgZ3HpsTswRACgDcEiBfEgXZLHXzt9KGR1UkpY-WjTDKLsQlSe1AvUo1c8lGyOzVppbULs6f6w1tiQ6tCgSoP7s2JaUvVSc09_-slKUqKIoKitwTAA3pj-upE1r23mSy2qaCs4_JdE5LocUptIMvoxU6kc1QVQgjvPyYX2PAgI-h1XSMv5xiIaVBH5G-s0qebfKVeQ1hVQpmrPvvK6pjJ5GYZEU_VYDQbTdHfWLu3hF1fKTeuwtYS4-D3DhaNlt0n54o4fmLgUjtqYl7j3Zb4WM3kULBeGPYqa61FkA",
  "payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogInZhdWx0Lm9mZmNsa2Fhbi5kZSIKICAgIH0KICBdCn0"
2024-08-11 20:06:49,521:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 429 324
2024-08-11 20:06:49,521:DEBUG:acme.client:Received response:
HTTP 429
Server: nginx
Date: Sun, 11 Aug 2024 18:06:49 GMT
Content-Type: application/problem+json
Content-Length: 324
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index", <https://letsencrypt.org/docs/rate-limits>;rel="help"
Replay-Nonce: cgBcsAuLWKUw2j8pYfaH5YgPvGH-AZ0TpEn7gcLodUUdccnsSls
Retry-After: 104864
  "type": "urn:ietf:params:acme:error:rateLimited",
  "detail": "Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: vault.offclkaan.de, retry after 2024-08-12T23:14:33Z: see https://letsencrypt.org/docs/duplicate-certificate-limit/",
  "status": 429
2024-08-11 20:06:49,521:DEBUG:certbot._internal.log:Exiting abnormally:
  File "/usr/lib/python3.11/contextlib.py", line 155, in __exit__
    self.gen.throw(typ, value, traceback)
  File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1683, in make_displayer
    yield displayer
  File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1736, in main
  File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1440, in run
    new_lineage = _get_and_save_cert(le_client, config, domains,
  File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 138, in _get_and_save_cert
  File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 516, in obtain_and_enroll_certificate
  File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 428, in obtain_certificate
  File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 478, in _get_order_and_authorizations
    orderr = self.acme.new_order(csr_pem)
  File "/usr/lib/python3/dist-packages/acme/client.py", line 138, in new_order
    response = self._post(self.directory['newOrder'], order)
  File "/usr/lib/python3/dist-packages/acme/client.py", line 338, in _post
    return self.net.post(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/acme/client.py", line 711, in post
    return self._post_once(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/acme/client.py", line 724, in _post_once
    response = self._check_response(response, content_type=content_type)
  File "/usr/lib/python3/dist-packages/acme/client.py", line 575, in _check_response
    raise messages.Error.from_json(jobj)
acme.messages.Error: urn:ietf:params:acme:error:rateLimited :: There were too many requests of a given type :: Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: vault.offclkaan.de, retry after 2024-08-12T23:14:33Z: see https://letsencrypt.org/docs/duplicate-certificate-limit/
  File "/usr/bin/certbot", line 33, in <module>
    sys.exit(load_entry_point('certbot==2.1.0', 'console_scripts', 'certbot')())
  File "/usr/lib/python3/dist-packages/certbot/main.py", line 19, in main
  File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1733, in main
    with make_displayer(config) as displayer:
  File "/usr/lib/python3.11/contextlib.py", line 188, in __exit__
    exc.__traceback__ = traceback
  File "/usr/lib/python3/dist-packages/josepy/util.py", line 191, in __setattr__
    raise AttributeError("can't set attribute")
AttributeError: can't set attribute
2024-08-11 20:06:49,523:ERROR:certbot._internal.log:An unexpected error occurred:
2024-08-11 20:06:49,523:ERROR:certbot._internal.log:AttributeError: can't set attribute
2024-08-11 20:07:39,729:DEBUG:certbot._internal.main:certbot version: 2.1.0
2024-08-11 20:07:39,729:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
2024-08-11 20:07:39,729:DEBUG:certbot._internal.main:Arguments: ['--apache']
2024-08-11 20:07:39,729:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2024-08-11 20:07:39,733:DEBUG:certbot._internal.log:Root logging level set at 30
2024-08-11 20:07:39,733:DEBUG:certbot._internal.plugins.selection:Requested authenticator apache and installer apache
2024-08-11 20:07:39,766:DEBUG:certbot_apache._internal.configurator:Apache version is 2.4.61
2024-08-11 20:07:39,861:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * apache
Initialized: <certbot_apache._internal.override_debian.DebianConfigurator object at 0x7f6c00734d50>
Prep: True
2024-08-11 20:07:39,861:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot_apache._internal.override_debian.DebianConfigurator object at 0x7f6c00734d50> and installer <certbot_apache._internal.override_debian.DebianConfigurator object at 0x7f6c00734d50>
2024-08-11 20:07:39,861:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator apache, Installer apache
2024-08-11 20:07:39,905:DEBUG:certbot._internal.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letsencrypt.org/acme/acct/1885871776', new_authzr_uri=None, terms_of_service=None), 83b783c1df78fc63c0d2bd7960fdd9b3, Meta(creation_dt=datetime.datetime(2024, 8, 11, 18, 6, 44, tzinfo=<UTC>), creation_host='vault.offclkaan.de', register_to_eff='mail@fastlayer.eu'))>
2024-08-11 20:07:39,905:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2024-08-11 20:07:39,906:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2024-08-11 20:07:40,393:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 746
2024-08-11 20:07:40,394:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 11 Aug 2024 18:07:40 GMT
Content-Length: 746
  "meta": {
    "caaIdentities": [
      "letsencrypt.org"
  "revokeCert": "https://acme-v02.api.letsencrypt.org/acme/revoke-cert",
  "xVBNguZYcKY": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417"
2024-08-11 20:07:42,019:DEBUG:certbot._internal.display.obj:Notifying user: Requesting a certificate for vault.offclkaan.de
2024-08-11 20:07:42,020:DEBUG:certbot.crypto_util:Generating ECDSA key (2048 bits): /etc/letsencrypt/keys/0001_key-certbot.pem
2024-08-11 20:07:42,022:DEBUG:certbot.crypto_util:Creating CSR: /etc/letsencrypt/csr/0001_csr-certbot.pem
2024-08-11 20:07:42,022:DEBUG:acme.client:Requesting fresh nonce
2024-08-11 20:07:42,022:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2024-08-11 20:07:42,185:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2024-08-11 20:07:42,185:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 11 Aug 2024 18:07:42 GMT
Replay-Nonce: BbYiUXJNY9MJqMABzxdhyyuNyP2a2LU4ReSl4TpmHs9nlGHpUd0
2024-08-11 20:07:42,185:DEBUG:acme.client:Storing nonce: BbYiUXJNY9MJqMABzxdhyyuNyP2a2LU4ReSl4TpmHs9nlGHpUd0
2024-08-11 20:07:42,185:DEBUG:acme.client:JWS payload:
2024-08-11 20:07:42,188:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTg4NTg3MTc3NiIsICJub25jZSI6ICJCYllpVVhKTlk5TUpxTUFCenhkaHl5dU55UDJhMkxVNFJlU2w0VHBtSHM5bmxHSHBVZDAiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL25ldy1vcmRlciJ9",
  "signature": "bsES3X-tbucWSSVqFuYC0y1yOF7BnRubrHQK4IaxGqpiGL1PyD5D0Ba-kEsVbcWMoT29Z36L5UBp2ZMAxTDNw8_Exhtpi6eywvaHuxl_PrmQDFZ8sl16G7FWFqdmol80uBhE7HnuBe9EA6ZdASJjkM1L66q1yaPNjhZ-ctw1738PNmO5FiIok76naX9rE0bpSWbg8no8imbDgVrFA9TGolfxAlR_DTuG2rOx8RYv-pyFXZm53LhfdwItN8VV4M_UpyLencQLAft6GQH3tdhxEskp0oHf1xNyQTsMzRcZr-NdTUHri4_NqbCQTCFgPw1qy2ztPFOdsq3cuQbyF2xVLw",
2024-08-11 20:07:42,383:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 429 324
2024-08-11 20:07:42,384:DEBUG:acme.client:Received response:
HTTP 429
Server: nginx
Content-Length: 324
Replay-Nonce: cgBcsAuLEwiFFgMTSMiOATWr2CQQPUA6rBxuskdVW3xLOEOcM00
Retry-After: 104811
  "status": 429
2024-08-11 20:07:42,384:DEBUG:certbot._internal.log:Exiting abnormally:
    yield displayer
2024-08-11 20:07:42,386:ERROR:certbot._internal.log:An unexpected error occurred:
2024-08-11 20:07:42,386:ERROR:certbot._internal.log:AttributeError: can't set attribute
2024-08-11 20:10:55,930:DEBUG:certbot._internal.main:certbot version: 2.1.0
2024-08-11 20:10:55,930:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
2024-08-11 20:10:55,931:DEBUG:certbot._internal.main:Arguments: ['--apache']
2024-08-11 20:10:55,931:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2024-08-11 20:10:55,935:DEBUG:certbot._internal.log:Root logging level set at 30
2024-08-11 20:10:55,935:DEBUG:certbot._internal.plugins.selection:Requested authenticator apache and installer apache
2024-08-11 20:10:55,967:DEBUG:certbot_apache._internal.configurator:Apache version is 2.4.61
2024-08-11 20:10:56,060:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * apache
Initialized: <certbot_apache._internal.override_debian.DebianConfigurator object at 0x7f78cd20cc10>
Prep: True
2024-08-11 20:10:56,061:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot_apache._internal.override_debian.DebianConfigurator object at 0x7f78cd20cc10> and installer <certbot_apache._internal.override_debian.DebianConfigurator object at 0x7f78cd20cc10>
2024-08-11 20:10:56,061:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator apache, Installer apache
2024-08-11 20:10:56,104:DEBUG:certbot._internal.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letsencrypt.org/acme/acct/1885871776', new_authzr_uri=None, terms_of_service=None), 83b783c1df78fc63c0d2bd7960fdd9b3, Meta(creation_dt=datetime.datetime(2024, 8, 11, 18, 6, 44, tzinfo=<UTC>), creation_host='vault.offclkaan.de', register_to_eff='mail@fastlayer.eu'))>
2024-08-11 20:10:56,105:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2024-08-11 20:10:56,105:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2024-08-11 20:10:56,495:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 746
2024-08-11 20:10:56,495:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 11 Aug 2024 18:10:56 GMT
Content-Length: 746
  "QlRHmQrHBFA": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
  "meta": {
    "caaIdentities": [
      "letsencrypt.org"
2024-08-11 20:10:57,727:DEBUG:certbot._internal.display.obj:Notifying user: Requesting a certificate for vault.offclkaan.de
2024-08-11 20:10:57,729:DEBUG:certbot.crypto_util:Generating ECDSA key (2048 bits): /etc/letsencrypt/keys/0002_key-certbot.pem
2024-08-11 20:10:57,731:DEBUG:certbot.crypto_util:Creating CSR: /etc/letsencrypt/csr/0002_csr-certbot.pem
2024-08-11 20:10:57,731:DEBUG:acme.client:Requesting fresh nonce
2024-08-11 20:10:57,731:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2024-08-11 20:10:57,860:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2024-08-11 20:10:57,861:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 11 Aug 2024 18:10:57 GMT
Replay-Nonce: bXG0Ugg-m-ytoE_sGljGbZRJbq3F7eA3SToKnxyF74EPxcufsfA
2024-08-11 20:10:57,861:DEBUG:acme.client:Storing nonce: bXG0Ugg-m-ytoE_sGljGbZRJbq3F7eA3SToKnxyF74EPxcufsfA
2024-08-11 20:10:57,861:DEBUG:acme.client:JWS payload:
2024-08-11 20:10:57,863:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTg4NTg3MTc3NiIsICJub25jZSI6ICJiWEcwVWdnLW0teXRvRV9zR2xqR2JaUkpicTNGN2VBM1NUb0tueHlGNzRFUHhjdWZzZkEiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL25ldy1vcmRlciJ9",
  "signature": "CpQcTkd_wlR-f5TR1sllJoOR0i0EtvxlJL7kXS1fH8erfBAYgEqFojWx8J3GXTLDIF7_crFNFQ1VWOgV4_7bECWtZtm24wuGfubxGOBydYQFIEyFq9w39iJkYL3G-8G8aIaYnHok_qgukPDVIfrK5KDa2Zr4cXZx7TVQ15H48GDTaJQDrGm0T8KKtLSn8VbbaSk4n5gos0TLhK3Et_xz-AEa1SAxyleFayJL4wCBsZL3hXkCZlhUbeyk2FYIetyLcipcV8-tPD5LMnmYmhmr_TSyXRqYhRBNSHKlXY5p6e0bXCWJCP459TkTP4IQVEMiQSm0CI7UJ_gEqouSsPSoDQ",
2024-08-11 20:10:58,014:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 429 324
2024-08-11 20:10:58,014:DEBUG:acme.client:Received response:
HTTP 429
Server: nginx
Content-Length: 324
Replay-Nonce: hgpogSPu7jM3DcdDT8seuy16WJIOSSfVR4Ixlxq3-erIxhn5oGM
Retry-After: 104615
  "status": 429
2024-08-11 20:10:58,014:DEBUG:certbot._internal.log:Exiting abnormally:
    yield displayer
2024-08-11 20:10:58,016:ERROR:certbot._internal.log:An unexpected error occurred:
2024-08-11 20:10:58,016:ERROR:certbot._internal.log:AttributeError: can't set attribute
How do you do? I have a problem with CertBot. I have tried at least 10 times today and reinstalled my server again and again, but unfortunately without success. How can I finally install Certbot? I get this error message all the time.
Please help
The first thing is to update your version of Certbot. Version 2.3 fixed a bug which looks exactly like what you show: Certbot 2.3.0 Release
The current version is 2.11
This bug just prevents showing why the cert request failed. So, something else is failing too. But, it will be very helpful to know the original reason for failing once you update.
The Certbot team recommend using the snap install so that it stays updated. You can follow the instructions for Debian 10
From the log in the first reply:
:wink:
I believe the AttributeError only is an issue when there's an error from the ACME server.. So this would mean OP has gotten 5 perfectly fine certificates before running into the AttributeError..
@offclkaan Please use one of the previously issued 5 certificates, thank you.
I cannot update my Certbot.
And I wasn't issued a certificate at all, otherwise it would have worked straight away. I got the same error messages every time.
Ah, yes.
The underlying problem is probably related to this failure using HTTPS. HTTP works fine
curl -i https://vault.offclkaan.de
curl: (35) error:0A00010B:SSL routines::wrong version number
curl -I http://vault.offclkaan.de
HTTP/1.1 200 OK
Date: Sun, 11 Aug 2024 18:44:00 GMT
Server: Apache/2.4.61 (Debian)
A little surprised to see such an error when using --apache plugin.
We should probably look at this output
sudo apache2ctl -t -D DUMP_VHOSTS
You definitely got 5 certs for vault already. Please see output of sudo certbot certificates
This is not the first time I have installed Bitwarden and Vaultwarden. I also know how to install Certbot, but today was the first time I had such a problem. And I don't know what the problem is...
Well, Let's Encrypt issued 5 certificates in the time span of just 10 minutes: crt.sh | vault.offclkaan.de
But there's something else weird going on in your log:
It's registering a new account.. But why would Certbot do that?
Is the directory /etc/letsencrypt/ ephemeral for some reason perhaps?
I have reinstalled the server.
Before or after you got 5 certs between Aug 11 14:28:38 2024 GMT and Aug 11 14:38:33 2024 GMT?
I have installed my server a few times today. And there was always the same error message. Today I could not install it at all. At crt.sh you can also see that I also had normal certificates at that time, but today 5x it can be yes, but none of it showed me or worked.
Well, you are at your limit of certs per week for that exact domain name. You could get a cert from another Certificate Authority until you can get more from Let's Encrypt. Or, maybe try the work-around suggested here: Duplicate Certificate Limit - Let's Encrypt
You were not having a problem getting a cert. You were having a problem configuring Apache to use it. It might be related to the problem in your Apache config that you have two VirtualHosts for the same domain name and port. While Apache will start with those settings you won't get the correct result. And, this could interfere with Certbot configuring your VirtualHost for port 443.
