Cert not trusted
My domain is:aewa.org
I ran this command: https://www.sslchecker.com
It produced this output: SSL is not trusted
My web server is (include version): Apache/2.4.37 (Rocky Linux)
The operating system my web server runs on is (include version): Rocky 8 (Linux)
My hosting provider, if applicable, is: Google WS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.22.0
I am not sure why that site reports the failure.
But, it is a bug with that sslchecker site.
Try using it to test letsencrypt.org which is the main website for Let's Encrypt. It fails the same.
We usually use SSL Labs or this SSL Checker and both report good results
See: SSL Server Test: aewa.org (Powered by Qualys SSL Labs)
Or: SSL Checker
Using openssl from my own test server also shows a valid cert and chain.
You should ignore that site's results. They are probably looking for specific intermediate (chain) certificates that have been obsolete for a long time (R3 specifically). It looks like they also don't tend to their own site very well. This is on their home page:
OK, Thanks, I'll ignore it. I just now tried https://www.ssllabs.com and it came back all OK.
