My domain is: www.jlambertphotos.com
I ran this command using the ruby acme-client version 0.6.3.
def csr
csr = OpenSSL::X509::Request.new
csr.subject = OpenSSL::X509::Name.new(
[['CN', domain, OpenSSL::ASN1::UTF8STRING]]
private_key = OpenSSL::PKey::RSA.new(key)
csr.public_key = private_key.public_key
csr.sign(private_key, OpenSSL::Digest::SHA256.new)
csr
end
LetsEncrypt.client.new_certificate(csr)
It generates a certificate, but when I use a ssl checker such as digicert.com/help, it shows that the TLS certificate is not trust, with the following message:
The certificate is not signed by a trusted authority (checking against Mozilla's root store). If you bought the certificate from a trusted authority, you probably just need to install one or more Intermediate certificates. Contact your certificate provider for assistance doing this for your server platform.
My web server is (include version): nginx 1.16.0
The operating system my web server runs on is (include version): aws linux.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): ruby acme-client version 0.6.3
