SSL / Port 80 issues
My domain is: sharing.ciol.org.uk
1: sharing.ciol.org.uk
blank to select all options shown (Enter ‘c’ to cancel): 1
tls-sni-01 challenge for sharing.ciol.org.uk
Error while running apache2ctl graceful.
httpd not running, trying to start
Action ‘graceful’ failed.
AH00112: Warning: DocumentRoot [/var/lib/letsencrypt/tls_sni_01_page/] does not exist
(98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
(98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
AH00015: Unable to open logs
Encountered exception during recovery
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 1998, in _reload
util.run_script(self.constant(“restart_cmd”))
File “/usr/lib/python3/dist-packages/certbot/util.py”, line 85, in run_script
raise errors.SubprocessError(msg)
certbot.errors.SubprocessError: Error while running apache2ctl graceful.
File “/usr/lib/python3/dist-packages/certbot/auth_handler.py”, line 124, in _solve_challenges
resp = self.auth.perform(all_achalls)
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 2084, in perform
self.restart()
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 1989, in restart
self._reload()
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 2000, in _reload
raise errors.MisconfigurationError(str(err))
certbot.errors.MisconfigurationError: Error while running apache2ctl graceful.
File “/usr/lib/python3/dist-packages/certbot/error_handler.py”, line 100, in _call_registered
self.funcs-1
File “/usr/lib/python3/dist-packages/certbot/auth_handler.py”, line 303, in _cleanup_challenges
self.auth.cleanup(achalls)
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 2109, in cleanup
self.restart()
self._reload()
The operating system my web server runs on is (include version): Ubuntu 14.04 (Trusty)
My hosting provider, if applicable, is: AWS
It appears that Apache is not running. Have you checked it? Is your website up?
Ok, checked that and Apache IS running though it is not serving your site. It is currently serving the Apache2 Ubuntu Default Page.
You need to properly configure Apache to serve your site before you can obtain certs.
Hello ciol
the tls-sni-01 - challenge is outdated. Use the http-01 or dns-01 - challenge. Perhaps update your certbot.
