Hello, I have a problem that I can’t solve.
sudo certbot --apache
root@ip-172-26-29-19:/home/bitnami# sudo certbot --apache
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter 'c' to cancel): aidenwong.com
http-01 challenge for aidenwong.com
Enabled Apache rewrite module
Error while running apache2ctl graceful.
httpd not running, trying to start
Action 'graceful' failed.
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1. Set the 'ServerName' directive globally to suppress this message
(98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
(98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
AH00015: Unable to open logs
Unable to restart apache using ['apache2ctl', 'graceful']
Encountered exception during recovery:
File "/usr/lib/python3/dist-packages/certbot_apache/configurator.py", line 2185, in _reload
util.run_script(self.option("restart_cmd"))
File "/usr/lib/python3/dist-packages/certbot/util.py", line 86, in run_script
raise errors.SubprocessError(msg)
certbot.errors.SubprocessError: Error while running apache2ctl graceful.
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 75, in handle_authorizations
resp = self._solve_challenges(aauthzrs)
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 139, in _solve_challenges
resp = self.auth.perform(all_achalls)
File "/usr/lib/python3/dist-packages/certbot_apache/configurator.py", line 2287, in perform
self.restart()
File "/usr/lib/python3/dist-packages/certbot_apache/configurator.py", line 2175, in restart
self._reload()
File "/usr/lib/python3/dist-packages/certbot_apache/configurator.py", line 2203, in _reload
raise errors.MisconfigurationError(error)
certbot.errors.MisconfigurationError: Error while running apache2ctl graceful.
File "/usr/lib/python3/dist-packages/certbot/error_handler.py", line 108, in _call_registered
self.funcs[-1]()
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 323, in _cleanup_challenges
self.auth.cleanup(achalls)
File "/usr/lib/python3/dist-packages/certbot_apache/configurator.py", line 2312, in cleanup
self.restart()
self._reload()
apache PHP 7.2.17
Ubuntu 16.04.6 LTS
Amazon Lightsail
WordPress 5.2.2
certbot 0.31.0
Thanks for your help!
