Certbot mistakes my ip and localhost (and more errors)
My domain is: calmera.es
I ran this command: sudo certbot --apache certonly
Error while running apache2ctl graceful.
httpd not running, trying to start
Action ‘graceful’ failed.
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 127.0.0.1. Set the ‘ServerName’ directive globall y to suppress this message
(98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
(98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
AH00015: Unable to open logs
Encountered exception during recovery
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 1998, in _reload
util.run_script(self.constant(“restart_cmd”))
File “/usr/lib/python3/dist-packages/certbot/util.py”, line 85, in run_script
raise errors.SubprocessError(msg)
certbot.errors.SubprocessError: Error while running apache2ctl graceful.
File “/usr/lib/python3/dist-packages/certbot/auth_handler.py”, line 124, in _solve_challenges
resp = self.auth.perform(all_achalls)
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 2084, in perform
self.restart()
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 1989, in restart
self._reload()
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 2000, in _reload
raise errors.MisconfigurationError(str(err))
certbot.errors.MisconfigurationError: Error while running apache2ctl graceful.
File “/usr/lib/python3/dist-packages/certbot/error_handler.py”, line 100, in _call_registered
self.funcs-1
File “/usr/lib/python3/dist-packages/certbot/auth_handler.py”, line 303, in _cleanup_challenges
self.auth.cleanup(achalls)
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 2109, in cleanup
self.restart()
self._reload()
My web server is (include version): Ubuntu 16.04 LTS
Can you stop Apache and then run:
sudo ss -tlnp
sudo grep -Rei Listen /etc/apache2/conf*
Thanks in advance. I did that, and this is the output:
ubuntu@servidor-1:~$ sudo ss -tlnp
State Recv-Q Send-Q Local Address:Port Peer Address:Port
LISTEN 0 80 127.0.0.1:3306 : users:((“mysqld”,pid=22492,fd=38))
LISTEN 0 128 :22 : users:((“sshd”,pid=7133,fd=3))
LISTEN 0 128 :::80 :::
users:(("/opt/lampp/bin/",pid=31637,fd=4),("/opt/lampp/bin/",pid=31625,fd=4),("/ opt/lampp/bin/",pid=31587,fd=4),("/opt/lampp/bin/",pid=31558,fd=4),("/opt/lampp/ bin/",pid=31557,fd=4),("/opt/lampp/bin/",pid=31490,fd=4),("/opt/lampp/bin/",pid= 31469,fd=4),("/opt/lampp/bin/",pid=31419,fd=4),("/opt/lampp/bin/",pid=31312,fd=4 ),("/opt/lampp/bin/",pid=31183,fd=4),("/opt/lampp/bin/",pid=12849,fd=4),("/opt/l ampp/bin/",pid=2285,fd=4))
LISTEN 0 5 :::21 :::* users:((“proftpd”,pid=2338,fd=0))
LISTEN 0 128 :::22 :::* users:((“sshd”,pid=7133,fd=4))
LISTEN 0 128 :::443 :::* users:(("/opt/lampp/bin/",pid=31637,fd=6),("/opt/lampp/bin/",pid=31625,fd=6),("/ opt/lampp/bin/",pid=31587,fd=6),("/opt/lampp/bin/",pid=31558,fd=6),("/opt/lampp/ bin/",pid=31557,fd=6),("/opt/lampp/bin/",pid=31490,fd=6),("/opt/lampp/bin/",pid= 31469,fd=6),("/opt/lampp/bin/",pid=31419,fd=6),("/opt/lampp/bin/",pid=31312,fd=6 ),("/opt/lampp/bin/",pid=31183,fd=6),("/opt/lampp/bin/",pid=12849,fd=6),("/opt/l ampp/bin/",pid=2285,fd=6))
And then:
ubuntu@servidor-1:~$ sudo grep -Rei Listen /etc/apache2/conf*
grep: Listen: No such file or directory
/etc/apache2/conf-available/charset.conf:# Read the documentation before enablin g AddDefaultCharset.
/etc/apache2/conf-available/charset.conf:# In general, it is only a good idea if you know that all your files
/etc/apache2/conf-available/charset.conf:# have this encoding. It will override any encoding given in the files
/etc/apache2/conf-available/charset.conf:# in meta http-equiv or xml encoding ta gs.
/etc/apache2/conf-available/charset.conf:# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
/etc/apache2/conf-available/security.conf:# Disable access to the entire file sy stem except for the directories that
/etc/apache2/conf-available/security.conf:# are explicitly allowed later.
/etc/apache2/conf-available/security.conf:# This currently breaks the configurat ions that come with some web application
/etc/apache2/conf-available/security.conf:# Debian packages.
/etc/apache2/conf-available/security.conf:# AllowOverride None
/etc/apache2/conf-available/security.conf:# Require all denied
/etc/apache2/conf-available/security.conf:# Changing the following options will not really affect the security of the
/etc/apache2/conf-available/security.conf:# server, but might make attacks sligh tly more difficult in some cases.
/etc/apache2/conf-available/security.conf:# This directive configures what you r eturn as the Server HTTP response
/etc/apache2/conf-available/security.conf:# Header. The default is ‘Full’ which sends information about the OS-Type
/etc/apache2/conf-available/security.conf:# and compiled in modules.
/etc/apache2/conf-available/security.conf:# Set to one of: Full | OS | Minimal | Minor | Major | Prod
/etc/apache2/conf-available/security.conf:# where Full conveys the most informat ion, and Prod the least.
/etc/apache2/conf-available/security.conf:#ServerTokens Minimal
/etc/apache2/conf-available/security.conf:# Optionally add a line containing the server version and virtual host
/etc/apache2/conf-available/security.conf:# name to server-generated pages (inte rnal error documents, FTP directory
/etc/apache2/conf-available/security.conf:# listings, mod_status and mod_info ou tput etc., but not CGI generated
/etc/apache2/conf-available/security.conf:# Set to “EMail” to also include a mai lto: link to the ServerAdmin.
/etc/apache2/conf-available/security.conf:# Set to one of: On | Off | EMail
/etc/apache2/conf-available/security.conf:#ServerSignature Off
/etc/apache2/conf-available/security.conf:ServerSignature On
/etc/apache2/conf-available/security.conf:# Set to “extended” to also reflect th e request body (only for testing and
/etc/apache2/conf-available/security.conf:# diagnostic purposes).
/etc/apache2/conf-available/security.conf:# Forbid access to version control dir ectories
/etc/apache2/conf-available/security.conf:# If you use version control systems i n your document root, you should
/etc/apache2/conf-available/security.conf:# probably deny access to their direct ories. For example, for subversion:
/etc/apache2/conf-available/security.conf:#<DirectoryMatch “/.svn”>
/etc/apache2/conf-available/security.conf:# Setting this header will prevent MSI E from interpreting files as something
/etc/apache2/conf-available/security.conf:# else than declared by the content ty pe in the HTTP headers.
/etc/apache2/conf-available/security.conf:# Requires mod_headers to be enabled.
/etc/apache2/conf-available/security.conf:#Header set X-Content-Type-Options: “n osniff”
/etc/apache2/conf-available/security.conf:# Setting this header will prevent oth er sites from embedding pages from this
/etc/apache2/conf-available/security.conf:# site as frames. This defends against clickjacking attacks.
/etc/apache2/conf-available/security.conf:#Header set X-Frame-Options: “sameorig in”
/etc/apache2/conf-available/security.conf:# vim: syntax=apache ts=4 sw=4 sts=4 s r noet
/etc/apache2/conf-available/localized-error-pages.conf:# Customizable error resp onses come in three flavors:
/etc/apache2/conf-available/localized-error-pages.conf:# 1) plain text
/etc/apache2/conf-available/localized-error-pages.conf:# 2) local redirects
/etc/apache2/conf-available/localized-error-pages.conf:# 3) external redirects
/etc/apache2/conf-available/localized-error-pages.conf:#ErrorDocument 404 /missi ng.html
/etc/apache2/conf-available/localized-error-pages.conf:#ErrorDocument 404 “/cgi- bin/missing_handler.pl”
/etc/apache2/conf-available/localized-error-pages.conf:#ErrorDocument 402 http:/ /www.example.com/subscription_info.html
/etc/apache2/conf-available/localized-error-pages.conf:# Putting this all togeth er, we can internationalize error responses.
/etc/apache2/conf-available/localized-error-pages.conf:# We use Alias to redirec t any /error/HTTP_.html.var response to
/etc/apache2/conf-available/localized-error-pages.conf:# our collection of by-er ror message multi-language collections. We use
/etc/apache2/conf-available/localized-error-pages.conf:# includes to substitute the appropriate text.
/etc/apache2/conf-available/localized-error-pages.conf:# You can modify the mess ages’ appearance without changing any of the
/etc/apache2/conf-available/localized-error-pages.conf:# default HTTP_.ht ml.var files by adding the line:
/etc/apache2/conf-available/localized-error-pages.conf:#Alias /error/include/ “/ your/include/path/”
/etc/apache2/conf-available/localized-error-pages.conf:# which allows you to cre ate your own set of files by starting with the
/etc/apache2/conf-available/localized-error-pages.conf:# /usr/share/apache2/erro r/include/ files and copying them to /your/include/path/,
/etc/apache2/conf-available/localized-error-pages.conf:# even on a per-VirtualHo st basis. If you include the Alias in the global server
/etc/apache2/conf-available/localized-error-pages.conf:# context, is has to come before the ‘Alias /error/ …’ line.
/etc/apache2/conf-available/localized-error-pages.conf:# The default include fil es will display your Apache version number and your
/etc/apache2/conf-available/localized-error-pages.conf:# ServerAdmin email addre ss regardless of the setting of ServerSignature.
/etc/apache2/conf-available/localized-error-pages.conf:# WARNING: The configurat ion below will NOT work out of the box if you have a
/etc/apache2/conf-available/localized-error-pages.conf:# SetHan dler directive in a context somewhere. Adding
/etc/apache2/conf-available/localized-error-pages.conf:# the fo llowing three lines AFTER the context should
/etc/apache2/conf-available/localized-error-pages.conf:# make i t work in most cases:
/etc/apache2/conf-available/localized-error-pages.conf:# <Locat ion /error/>
/etc/apache2/conf-available/localized-error-pages.conf:# </Loca tion>
/etc/apache2/conf-available/localized-error-pages.conf:# The internationalized e rror documents require mod_alias, mod_include
/etc/apache2/conf-available/localized-error-pages.conf:# and mod_negotiation. T o activate them, uncomment the following 37 lines.
/etc/apache2/conf-available/localized-error-pages.conf:# A lias /error/ “/usr/share/apache2/error/”
/etc/apache2/conf-available/localized-error-pages.conf:# < Directory “/usr/share/apache2/error”>
/etc/apache2/conf-available/localized-error-pages.conf:# O ptions IncludesNoExec
/etc/apache2/conf-available/localized-error-pages.conf:# A ddOutputFilter Includes html
/etc/apache2/conf-available/localized-error-pages.conf:# L anguagePriority en cs de es fr it nl sv pt-br ro
/etc/apache2/conf-available/localized-error-pages.conf:# F orceLanguagePriority Prefer Fallback
/etc/apache2/conf-available/localized-error-pages.conf:# < /Directory>
/etc/apache2/conf-available/localized-error-pages.conf:# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
/etc/apache2/conf-available/other-vhosts-access-log.conf:# Define an access log for VirtualHosts that don’t define their own logfile
/etc/apache2/conf-available/other-vhosts-access-log.conf:CustomLog ${APACHE_LOG_ DIR}/other_vhosts_access.log vhost_combined
/etc/apache2/conf-available/other-vhosts-access-log.conf:# vim: syntax=apache ts =4 sw=4 sts=4 sr noet
/etc/apache2/conf-available/serve-cgi-bin.conf:
/etc/apache2/conf-available/serve-cgi-bin.conf: Define ENABLE_USR_LIB_CG I_BIN
/etc/apache2/conf-available/serve-cgi-bin.conf: ScriptAlias /cgi-bin/ /u sr/lib/cgi-bin/
/etc/apache2/conf-available/serve-cgi-bin.conf: <Directory “/usr/lib/cgi -bin”>
/etc/apache2/conf-available/serve-cgi-bin.conf: AllowOverride No ne
/etc/apache2/conf-available/serve-cgi-bin.conf: Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
/etc/apache2/conf-available/serve-cgi-bin.conf: Require all gran ted
/etc/apache2/conf-available/serve-cgi-bin.conf:# vim: syntax=apache ts=4 sw=4 st s=4 sr noet
and continues:
/etc/apache2/conf-enabled/charset.conf:# Read the documentation before enabling AddDefaultCharset.
/etc/apache2/conf-enabled/charset.conf:# In general, it is only a good idea if y ou know that all your files
/etc/apache2/conf-enabled/charset.conf:# have this encoding. It will override an y encoding given in the files
/etc/apache2/conf-enabled/charset.conf:# in meta http-equiv or xml encoding tags .
/etc/apache2/conf-enabled/charset.conf:# vim: syntax=apache ts=4 sw=4 sts=4 sr n oet
/etc/apache2/conf-enabled/security.conf:# Disable access to the entire file syst em except for the directories that
/etc/apache2/conf-enabled/security.conf:# are explicitly allowed later.
/etc/apache2/conf-enabled/security.conf:# This currently breaks the configuratio ns that come with some web application
/etc/apache2/conf-enabled/security.conf:# Debian packages.
/etc/apache2/conf-enabled/security.conf:# AllowOverride None
/etc/apache2/conf-enabled/security.conf:# Require all denied
/etc/apache2/conf-enabled/security.conf:# Changing the following options will no t really affect the security of the
/etc/apache2/conf-enabled/security.conf:# server, but might make attacks slightl y more difficult in some cases.
/etc/apache2/conf-enabled/security.conf:# This directive configures what you ret urn as the Server HTTP response
/etc/apache2/conf-enabled/security.conf:# Header. The default is ‘Full’ which se nds information about the OS-Type
/etc/apache2/conf-enabled/security.conf:# and compiled in modules.
/etc/apache2/conf-enabled/security.conf:# Set to one of: Full | OS | Minimal | Minor | Major | Prod
/etc/apache2/conf-enabled/security.conf:# where Full conveys the most informatio n, and Prod the least.
/etc/apache2/conf-enabled/security.conf:#ServerTokens Minimal
/etc/apache2/conf-enabled/security.conf:# Optionally add a line containing the s erver version and virtual host
/etc/apache2/conf-enabled/security.conf:# name to server-generated pages (intern al error documents, FTP directory
/etc/apache2/conf-enabled/security.conf:# listings, mod_status and mod_info outp ut etc., but not CGI generated
/etc/apache2/conf-enabled/security.conf:# Set to “EMail” to also include a mailt o: link to the ServerAdmin.
/etc/apache2/conf-enabled/security.conf:# Set to one of: On | Off | EMail
/etc/apache2/conf-enabled/security.conf:#ServerSignature Off
/etc/apache2/conf-enabled/security.conf:ServerSignature On
/etc/apache2/conf-enabled/security.conf:# Set to “extended” to also reflect the request body (only for testing and
/etc/apache2/conf-enabled/security.conf:# diagnostic purposes).
/etc/apache2/conf-enabled/security.conf:# Forbid access to version control direc tories
/etc/apache2/conf-enabled/security.conf:# If you use version control systems in your document root, you should
/etc/apache2/conf-enabled/security.conf:# probably deny access to their director ies. For example, for subversion:
/etc/apache2/conf-enabled/security.conf:#<DirectoryMatch “/.svn”>
/etc/apache2/conf-enabled/security.conf:# Setting this header will prevent MSIE from interpreting files as something
/etc/apache2/conf-enabled/security.conf:# else than declared by the content type in the HTTP headers.
/etc/apache2/conf-enabled/security.conf:# Requires mod_headers to be enabled.
/etc/apache2/conf-enabled/security.conf:#Header set X-Content-Type-Options: “nos niff”
/etc/apache2/conf-enabled/security.conf:# Setting this header will prevent other sites from embedding pages from this
/etc/apache2/conf-enabled/security.conf:# site as frames. This defends against c lickjacking attacks.
/etc/apache2/conf-enabled/security.conf:#Header set X-Frame-Options: "sameorigin "
/etc/apache2/conf-enabled/security.conf:# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
/etc/apache2/conf-enabled/localized-error-pages.conf:# Customizable error respon ses come in three flavors:
/etc/apache2/conf-enabled/localized-error-pages.conf:# 1) plain text
/etc/apache2/conf-enabled/localized-error-pages.conf:# 2) local redirects
/etc/apache2/conf-enabled/localized-error-pages.conf:# 3) external redirects
/etc/apache2/conf-enabled/localized-error-pages.conf:#ErrorDocument 404 /missing .html
/etc/apache2/conf-enabled/localized-error-pages.conf:#ErrorDocument 404 “/cgi-bi n/missing_handler.pl”
/etc/apache2/conf-enabled/localized-error-pages.conf:#ErrorDocument 402 http://w ww.example.com/subscription_info.html
/etc/apache2/conf-enabled/localized-error-pages.conf:# Putting this all together , we can internationalize error responses.
/etc/apache2/conf-enabled/localized-error-pages.conf:# We use Alias to redirect any /error/HTTP_.html.var response to
/etc/apache2/conf-enabled/localized-error-pages.conf:# our collection of by-erro r message multi-language collections. We use
/etc/apache2/conf-enabled/localized-error-pages.conf:# includes to substitute th e appropriate text.
/etc/apache2/conf-enabled/localized-error-pages.conf:# You can modify the messag es’ appearance without changing any of the
/etc/apache2/conf-enabled/localized-error-pages.conf:# default HTTP_.html .var files by adding the line:
/etc/apache2/conf-enabled/localized-error-pages.conf:#Alias /error/include/ “/yo ur/include/path/”
/etc/apache2/conf-enabled/localized-error-pages.conf:# which allows you to creat e your own set of files by starting with the
/etc/apache2/conf-enabled/localized-error-pages.conf:# /usr/share/apache2/error/ include/ files and copying them to /your/include/path/,
/etc/apache2/conf-enabled/localized-error-pages.conf:# even on a per-VirtualHost basis. If you include the Alias in the global server
/etc/apache2/conf-enabled/localized-error-pages.conf:# context, is has to come _ before_ the ‘Alias /error/ …’ line.
/etc/apache2/conf-enabled/localized-error-pages.conf:# The default include files will display your Apache version number and your
/etc/apache2/conf-enabled/localized-error-pages.conf:# ServerAdmin email address regardless of the setting of ServerSignature.
/etc/apache2/conf-enabled/localized-error-pages.conf:# WARNING: The configuratio n below will NOT work out of the box if you have a
/etc/apache2/conf-enabled/localized-error-pages.conf:# SetHandler dir ective in a context somewhere. Adding
/etc/apache2/conf-enabled/localized-error-pages.conf:# the following three lines AFTER the context should
/etc/apache2/conf-enabled/localized-error-pages.conf:# make it work i n most cases:
/etc/apache2/conf-enabled/localized-error-pages.conf:# <Location /err or/>
/etc/apache2/conf-enabled/localized-error-pages.conf:# The internationalized err or documents require mod_alias, mod_include
/etc/apache2/conf-enabled/localized-error-pages.conf:# and mod_negotiation. To activate them, uncomment the following 37 lines.
/etc/apache2/conf-enabled/localized-error-pages.conf:# Alias /e rror/ “/usr/share/apache2/error/”
/etc/apache2/conf-enabled/localized-error-pages.conf:# <Directo ry “/usr/share/apache2/error”>
/etc/apache2/conf-enabled/localized-error-pages.conf:# O ptions IncludesNoExec
/etc/apache2/conf-enabled/localized-error-pages.conf:# A ddOutputFilter Includes html
/etc/apache2/conf-enabled/localized-error-pages.conf:# L anguagePriority en cs de es fr it nl sv pt-br ro
/etc/apache2/conf-enabled/localized-error-pages.conf:# F orceLanguagePriority Prefer Fallback
/etc/apache2/conf-enabled/localized-error-pages.conf:# </Direct ory>
/etc/apache2/conf-enabled/localized-error-pages.conf:# vim: syntax=apache ts=4 s w=4 sts=4 sr noet
/etc/apache2/conf-enabled/other-vhosts-access-log.conf:# Define an access log fo r VirtualHosts that don’t define their own logfile
/etc/apache2/conf-enabled/other-vhosts-access-log.conf:CustomLog ${APACHE_LOG_DI R}/other_vhosts_access.log vhost_combined
/etc/apache2/conf-enabled/other-vhosts-access-log.conf:# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
/etc/apache2/conf-enabled/serve-cgi-bin.conf:
/etc/apache2/conf-enabled/serve-cgi-bin.conf: Define ENABLE_USR_LIB_CG I_BIN
/etc/apache2/conf-enabled/serve-cgi-bin.conf: ScriptAlias /cgi-bin/ /u sr/lib/cgi-bin/
/etc/apache2/conf-enabled/serve-cgi-bin.conf: <Directory “/usr/lib/cgi -bin”>
/etc/apache2/conf-enabled/serve-cgi-bin.conf: AllowOverride No ne
/etc/apache2/conf-enabled/serve-cgi-bin.conf: Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
/etc/apache2/conf-enabled/serve-cgi-bin.conf: Require all gran ted
/etc/apache2/conf-enabled/serve-cgi-bin.conf:# vim: syntax=apache ts=4 sw=4 sts= 4 sr noet
That’s all
So you’re using XAMPP or similar?
If this is not a totally standard Apache installation on Ubuntu, you may need to pass some arguments to Certbot to allow it to understand your environment.
You can see these at
certbot --help apache
Yes. Ok, I guess that’s the problem.
Thanks,
I don’t understand:
“/opt/lampp/bin/”
I’d like to see output from:
netstat -napt | grep LISTEN
and the result of (without --apache):
sudo certbot certonly
In my server, I have a very personalized XAMPP installed in Ubuntu (I didn’t know, that was my fault). So I had running at the same time 2 Apache services (one in /apache and another in /opt/lampp).
I finally solved the issue by getting and installing the certificates and the key manually, and reconfiguring virtualhosts in the Apache service that I was actually using.
Thanks a lot
