Error - setting up Certbot auto on Bitnami LAMP stack
Hello all,
I working in a Bitnami LAMP stack and then cloned Certbot from Github in /tmp on my instance.
I got the following error after it performed the challenges.
Can anyone help with this one?
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated)  (Enter 'c' to cancel): www.binhngodaicao.com,binhngodaicao.com
http-01 challenge for www.binhngodaicao.com
http-01 challenge for binhngodaicao.com
Enabled Apache rewrite module
Error while running apache2ctl graceful.
httpd not running, trying to start
Action 'graceful' failed.
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1. Set the '
ServerName' directive globally to suppress this message
(98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
(98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
AH00015: Unable to open logs
Encountered exception during recovery
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1. Set the 'ServerName' directive globally to suppress this message
  File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/error_handler.py", line 100, in _call_registered
    self.funcs[-1]()
  File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 303, in _cleanup_challenges
    self.auth.cleanup(achalls)
  File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot_apache/configurator.py", line 2109, in cleanup
    self.restart()
  File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot_apache/configurator.py", line 1989, in restart
    self._reload()
  File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot_apache/configurator.py", line 2000, in _reload
    raise errors.MisconfigurationError(str(err))
MisconfigurationError: Error while running apache2ctl graceful.
root@lampstack-1-vm:/tmp/certbot#
RESOLVED
I just had to stop Apache before preceding.
Ben
