Help setting up
I’m completely new to this and was following the certbot installation
using bitnami ubuntu 14.04
hosting on amazon web services
I ran this
./certbot-auto
and this is what I got
Error while running apache2ctl graceful.
httpd not running, trying to start
Action 'graceful' failed.
AH00112: Warning: DocumentRoot [/var/lib/letsencrypt/tls_sni_01_page/] does not exist
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1. Set the 'ServerName' directive globally to suppress this message
(98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
(98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
AH00015: Unable to open logs
Encountered exception during recovery
  File "/home/bitnami/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/error_handler.py", line 99, in _call_registered
    self.funcs[-1]()
  File "/home/bitnami/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 280, in _cleanup_challenges
    self.auth.cleanup(achalls)
  File "/home/bitnami/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot_apache/configurator.py", line 1769, in cleanup
    self.restart()
  File "/home/bitnami/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot_apache/configurator.py", line 1658, in restart
    self._reload()
  File "/home/bitnami/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot_apache/configurator.py", line 1669, in _reload
    raise errors.MisconfigurationError(str(err))
MisconfigurationError: Error while running apache2ctl graceful.
Let me know if any other info is needed to help me
