SSL issue your connection is not private
My domain is: www.ibchospitality.com
My web server is (include version):Apache 2.14.18(ubuntu)
The operating system my web server runs on is (include version):Ubuntu 16.04.1 LTS
My hosting provider, if applicable, is:AWS
I have renewed ssl certificate for this domain and it shows it is valid till 15 August ,2018 but most of the times when I am visiting site it gives error “Your connection is not private” but when I am reload page it disappears (I did all stuff including clearing brower cache,open in incognive mode and even cleared network cached).
I also checked with Qualis Lab ssl checker and it gives “A” rating but mentioned problem occurs most of the time and shows certificate is expired on 12th May 2018.
You are serving different certificates for www.ibchospitality.com and ibchospitality.com.
Thanks for quick response bytecamp.
Now,I have added ibchospitality.com domain under certificate name www.ibchospitality.com
Here is output of command : sudo letsencrypt certificates
Certificate Name: www.ibchospitality.com
Domains: www.ibchospitality.com ibchospitality.com
Expiry Date: 2018-08-15 08:52:01+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/www.ibchospitality.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.ibchospitality.com/privkey.pem
still this problem occurs.
You - of course - have to configure your webserver accordingly. It has to use the files below /etc/letsencrypt/live/www.ibchospitality.com/, is this the case?
SSL conf file, configured as follows :
SSLCertificateFile /etc/letsencrypt/live/www.ibchospitality.com/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/www.ibchospitality.com/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/www.ibchospitality.com/chain.pem
is anything missing ?
No, this is correct. But I see your case: your server somehow delivers different certificates on subsequent requests.
AWS restart did the trick thanks for your assistance throughout this communication.
