Your connection is not private
My domain is: yourbasket.co.ke
I ran this command: accessing yourbasket.co.ke website
It produced this output: This server could not prove that it is yourbasket.co.ke ; its security certificate is from admin.yourbasket.co.ke . This may be caused by a misconfiguration or an attacker intercepting your connection.
My web server is (include version): AWS
The operating system my web server runs on is (include version): Ubuntu
My hosting provider, if applicable, is: Hostinger
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Not sure
Hi @Yourbasket, and welcome to the LE community forum :slight_smile:
These are two different names:
Before you can connect securely to a name, it requires a cert that covers that name.
Does that system have a cert for the admin name?
Hy @rg305, yourbasket.co.ke is the main domain and admin.yourbasket.co.ke is the subdomain.
The SSL certificates were installed automatically via Hostinger.
Then you should speak with "Hostinger" about HTTPS.
Both sites fail HTTPS connections via IPv6:
curl -Ii6 https://yourbasket.co.ke
curl: (35) error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error
curl -Ii6 https://admin.yourbasket.co.ke
One of the names also fails HTTPS connections via IPv4:
curl -Ii4 https://yourbasket.co.ke
curl: (51) SSL: no alternative certificate subject name matches target host name 'yourbasket.co.ke'
curl -Ii4 https://admin.yourbasket.co.ke
HTTP/1.1 200 OK
Date: Mon, 22 May 2023 16:24:32 GMT
Server: Apache/2.4.41 (Ubuntu)
Last-Modified: Fri, 19 May 2023 07:06:57 GMT
ETag: "284-5fc0691108c96"
Accept-Ranges: bytes
Content-Length: 644
Vary: Accept-Encoding
Content-Type: text/html
