Connection showing not secure
My domain is: localhost and connekted.pagekite.me
I ran this command: certbot certonly --webroot -w D:\Development\Certbot\acme -d connekted.pagekite.me
It produced this output: You have an existing certificate that has exactly the same domains or certificate name you requested and isn't close to expiry. etc
My web server is (include version): nginx 1.25
The operating system my web server runs on is (include version): windows 11
My hosting provider, if applicable, is: pagekite
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.6.0
Hello Everyone, I have recently been able to solve the problems with http/https and now the site is https everywhere including the html files but somehow it is still saying not secure. Most probably it being self signed?
and the warning in url
Additionally, for these reasons it is not loading in WebView of android.
You will never get a publicly trusted certificate for this name:
You can't use both of those names securely.
but, even when i look against connekted.pagekite.me/room1.html
It is still showing same issue. then how to solve the other one?
I get:
I can open your page without any issues.
The issue lies with the antivirus software you're using, you may want to complain about it to them.
I'd remove this piece of software altogether
No issues?
The link to the "upgrade" is:
Pagekite - TLS Certificate Bug
Well, at least without issues that the OP seems to be experiencing.
try with connekted.pagekite.me/house
No but same site,
  1. wont even load in webview and
  2. show similar not secure warning in android chrome
So you're getting the same error that's on RudyĘĽs screenshot or the KasperskyĘĽs one?
No im not getting that error , kaspersky one on pc. and no explicitly mentioned error on android, page wont load in web view
actually you are correct this would load sometimes and sometimes it wont. specially with mobile hotspots(cg-nat) so i think the problem is with pagekite.
But, if we ignore this for a while and focus on the localhost/house or [ip]/house shouldnt we not get this not secure message there?
No, that's expected, since the certificate doesn't certify localhost domain name as well as IPs. Perhaps this will be helpful:
