Help: Your connection is not private
My domain is: techecons.org
I ran this command: www.techecons.org
It produced this output: Your connection is not private
Attackers might be trying to steal your information from www.techecons.org (for example, passwords, messages, or credit cards). Learn more
NET::ERR_CERT_COMMON_NAME_INVALID
It asked me to return to safety . But I being owner, I proceeded to the 'unsafe' and got to the website. An invited reader would not have proceeded.
The operating system my web server runs on is (include version): I dont know (Linux?)
My hosting provider, if applicable, is: https://cp.stackclientportal.co.uk (
www.cpcloudhosting.com/stackcp-linux-cloud-hosting/)
I can login to a root shell on my machine (yes or no, or I don't know): I dont know
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): https://cp.stackclientportal.co.uk/manage
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): dont know. Am a novice
An ancient certificate from 2016 for a different hostname is configured at the server of your website. The same certificate is presented by the server when using random hostnames, so it's probably the default certificate and not specifically configured for your website.
Did you somehow enable HTTPS, SSL or TLS in the control panel of your website? Your hosting provider claims "Free Wildcard SSL Certificates" for "StackCP Linux Cloud Hosting". Check the site of your hosting provider to see how to enable it or open a ticket for help. There's not much we can do about it I'm afraid.
Hi @Kennethfat
checking your domain there is an active certificate - https://check-your-website.server-daten.de/?q=techecons.org#ct-logs
Let's Encrypt Authority X3 2020-10-27 2021-01-25 *.domainsotc.com, *.educationaladministrators.org, *.seadmin.org, *.sosscie.org, *.techecons.org, *.versesfromhell.com, domainsotc.com, educationaladministrators.org, seadmin.org, sosscie.org, techecons.org, versesfromhell.com, www.educationaladministrators.domainsotc.com, www.seadmin.domainsotc.com, www.sosscie.domainsotc.com, www.techecons.domainsotc.com - 16 entries
But it's not used.
Are these other domains your domains?
May be your hoster has created a certificate, but not installed.
So you see an expired certificate.
Ask your hoster or check, if the control panel has additional options to see / recreate / install the certificate.
If not, change your hoster.
Are these other domains your domains? yes
Thank you
I appreciate your input. Thanks
There are also a few things have not yet been mentioned:
server: Apache
x-powered-by: PHP/5.6.40
x-redirect-by: WordPress
x-provided-by: StackCDN
