SSL for Admin ISPCONFIG 3
My domain is: server.on3w-isp.tk
 letsencrypt certonly --webroot -w /var/www -d server.on3w-isp.tk
but i received error and in log.
My web server is (include version): apache2
The operating system my web server runs on is (include version):Ubuntu 16.04
The SSL not work in admin server.on3w-isp.tk:8080
from has that check for this? I see this topic : Get SSL certificate for ISPConfig admin from LetsEncrypt?
and help the zk for ssl in ispconfig, i have the same problem. You can help me with this? I understand so so about server. I see for the file 000-default. But the that see for change?
Follow Code:https://gist.github.com/BarbaraEster/ce055802a180c0014bc0f28666d2ee59
Thx!!!
Hi @BarbaraEster
the topic is old, from 2016. Using Google looks like there are now integrated ISPConfig - solutions to create a Letsencrypt certificate.
Sample:
ISPConfig panel > Sites > Website > Website Name , then click SSL and Let's Encrypt check buttons and save - to create Let's Encrypt SSL files and enable them for your server site
That's always the better solution.
Thx, i see for this before get help here.
In command > root@server:/usr/local/ispconfig/interface/ssl# cat ispserver.{key,crt} > ispserver.pem
cat: ispserver.key: No such file or directory
I have this. You can explaned for me?
Hi @BarbaraEster,
Have you follow all the steps from the HowToForge guide?
Enabling SSL For ISPConfig 3 Control Panel (Port 8080)
If you haven't enabled SSL during ISPConfig setup i.e. for its control panel at port 8080, enable it by typing ispconfig_update.sh in the terminal and select yes for SSL.
Checking SSL For ISPConfig 3 Control Panel (Port 8080)
Check your browser to confirm by opening ISPConfig control panel at port 8080. Note that you might get some warning at this stage since the created SSL files are self-signed but the browser will confirm that your ISPConfig has SSL enabled or otherwise.
Securing ISPConfig Website With Let's Encrypt SSL
If the above is done, go back to ISPConfig panel > Sites > Website > Website Name , then click SSL and Let's Encrypt check buttons and save - to create Let's Encrypt SSL files and enable them for your server site. If successful your server site shall now be using this Let's Encrypt SSL files but not your ISPConfig 8080 page. If unsuccessful, you will not be able to proceed further, so do check its log file for a clue.
Only after following the steps will you be able to proceed with that cat ispserver.{key,crt} > ispserver.pem step according to their documentation.
There appears to be a script that will do this process for you, though I cannot comment on it because I have never used it. GitHub - ahrasis/LE4ISPC: Let's Encrypt With Auto Updater for ISPConfig 3 Single or Multi Server Setup with Debian, Ubuntu or other similar derivatives as the server OS.
YES
YES
Securing ISPConfig Website With Let’s Encrypt SSL
YES
I return here per this motive, the SSL work in site normal. When this command i have this error:
Thx.
Whats is logic for this work? The files and patch right. I did not undanstand prossed.
Thx!
Command again>>>
root@server:/usr/local/ispconfig/interface/ssl# mv ispserver.crt ispserver.crt-(date +"%y%m%d%H%M%S").bak root@server:/usr/local/ispconfig/interface/ssl# mv ispserver.key ispserver.key-(date +"%y%m%d%H%M%S").bak
root@server:/usr/local/ispconfig/interface/ssl# mv ispserver.pem ispserver.pem-(date +"%y%m%d%H%M%S").bak mv: cannot stat 'ispserver.pem': No such file or directory root@server:/usr/local/ispconfig/interface/ssl# ln -s /etc/letsencrypt/live/(hostname -f)/fullchain.pem ispserver.crt
root@server:/usr/local/ispconfig/interface/ssl# ln -s /etc/letsencrypt/live/$(hostname -f)/privkey.pem ispserver.key
cat: ispserver.crt: No such file or directory
It seems like the tutorial is trying to be too clever with the commands like
They are assuming that your server has been set up to be named after its public DNS name, but that’s actually not a very common default nowadays (although perhaps ISPCONFIG itself tries to do this in some circumstances?). So they assume that running hostname -f will return the same name that was used to name the certificate, which is probably not true on your server at all.
Could you show us the output of running sudo certbot certificates?
Hello Very thanks for help. my apologies for long time to answer.
The output command:
root@server:/# certbot certificates
Found the following certs:
Certificate Name: on3w-isp.tk
Domains: on3w-isp.tk
Expiry Date: 2019-11-20 13:50:12+00:00 (VALID: 84 days)
Certificate Path: /etc/letsencrypt/live/on3w-isp.tk/fullchain.pem
Private Key Path: /etc/letsencrypt/live/on3w-isp.tk/privkey.pem
root@server:/#
Thanks!
My suggestion would be that you go back to following the tutorial, but wherever it says
you would instead write
The tutorial assumed that your server would know of its own DNS domain name, but it doesn’t, which isn’t particularly unusual. Therefore, writing it in explicitly should fix the instructions from the tutorial.
When you try again, if any of the commands from the tutorial responds with any message, you can show us that message so we can understand if anything went wrong. But I think it will probably work with the modification that I suggested above.
Hello Thx for help, i follow the tutorial and chance commands with domain>>
ln -s /etc/letsencrypt/live/on3w-isp.tk/fullchain.pem ispserver.crt
ln -s /etc/letsencrypt/live/on3w-isp.tk/privkey.pem ispserver.key
/etc/letsencrypt/archive/on3w-isp.tk/ IN_MODIFY ./etc/init.d/le_ispc_pem.sh
and i dont have anyway error in process.
But in finish tutorial, i acess domain and not work with ssl.
look>> https://server.on3w-isp.tk:8080/ and http://server.on3w-isp.tk:8080/ i have broken of html.
Have something error?
Thx!!!
About this script>> LE4ISPC
I dont install, i understand that is other service for help this. Or this do party for continue?
Thx!
@BarbaraEster,
Your on3w-isp.tk domain is serving the proper certificate according to this command output.
$ echo | openssl s_client -connect on3w-isp.tk:443 -servername on3w-isp.tk 2> /dev/null | openssl x509 -noout -subject -startdate -enddate
subject=CN = on3w-isp.tk
notBefore=Aug 22 13:50:12 2019 GMT
notAfter=Nov 20 13:50:12 2019 GMT
However, I see that server.on3w-isp.tk is also serving that same certificate which is incorrect. The important bit here is to take note of the subject=CN line compared to the domain you actually issued a certificate for.
$ certs server.on3w-isp.tk | openssl x509 -noout -subject -startdate -enddate
You may want to retry the entire process as indicated by @schoen SSL for Admin ISPCONFIG 3 but setting the path to /etc/letsencrypt/live/server.on3w-isp.tk instead.
hello thanks for help, but not work.
I do update in cert.
with this>>>>
certbot certonly --cert-name on3w-isp.tk -d on3w-isp.tk,server.on3w-isp.tk
1: Apache Web Server plugin (apache)
2: Spin up a temporary webserver (standalone)
3: Place files in webroot directory (webroot)
Select the appropriate number [1-3] then [enter] (press ‘c’ to cancel): 1
Plugins selected: Authenticator apache, Installer None
You are updating certificate on3w-isp.tk to include new domain(s):
  • server.on3w-isp.tk
You are also removing previously included domain(s):
(None)
Did you intend to make this change?
(U)pdate cert/©ancel: u
http-01 challenge for server.on3w-isp.tk
Waiting for verification…
Resetting dropped connection: acme-v02.api.letsencrypt.org
    Your cert will expire on 2019-11-26. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot
    again. To non-interactively renew all of your certificates, run
    “certbot renew”
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
Domains: on3w-isp.tk server.on3w-isp.tk
Expiry Date: 2019-11-26 18:51:06+00:00 (VALID: 89 days)
And i do the tutorial follow your orient, change for server.@
Command>>> I get error in dovecot and i desable the lines of SSL for continue. And the command $cat ispserver.{key,crt} > ispserver.pem
ALL Commands >>>>
cd /usr/local/ispconfig/interface/ssl/
root@server:/usr/local/ispconfig/interface/ssl# mv ispserver.pem ispserver.pem-(date +"%y%m%d%H%M%S").bak root@server:/usr/local/ispconfig/interface/ssl# ln -s /etc/letsencrypt/live/server.on3w-isp.tk/fullchain.pem ispserver.crt root@server:/usr/local/ispconfig/interface/ssl# ln -s /etc/letsencrypt/live/server.on3w-isp.tk/privkey.pem ispserver.key root@server:/usr/local/ispconfig/interface/ssl# cat ispserver.{key,crt} > ispserver.pem cat: ispserver.key: No such file or directory cat: ispserver.crt: No such file or directory root@server:/usr/local/ispconfig/interface/ssl# cat ispserver.{key,crt} > ispserver.pem cat: ispserver.key: No such file or directory cat: ispserver.crt: No such file or directory root@server:/usr/local/ispconfig/interface/ssl# chmod 600 ispserver.pem root@server:/usr/local/ispconfig/interface/ssl# cd /etc/postfix/ root@server:/etc/postfix# mv smtpd.cert smtpd.cert-(date +"%y%m%d%H%M%S").bak
root@server:/etc/postfix# mv smtpd.key smtpd.key-$(date +"%y%m%d%H%M%S").bak
root@server:/etc/postfix# ln -s /usr/local/ispconfig/interface/ssl/ispserver.crt smtpd.cert
root@server:/etc/postfix# ln -s /usr/local/ispconfig/interface/ssl/ispserver.key smtpd.key
root@server:/etc/postfix# service postfix restart
root@server:/etc/postfix# service dovecot restart
Job for dovecot.service failed because the control process exited with error code. See “systemctl status dovecot.service” and “journalctl -xe” for details.
root@server:/etc/postfix# systemctl status dovecot.service
● dovecot.service - Dovecot IMAP/POP3 email server
Loaded: loaded (/lib/systemd/system/dovecot.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2019-08-28 19:57:36 UTC; 12s ago
Docs: man:dovecot(1)
http://wiki2.dovecot.org/
Process: 8934 ExecStop=/usr/bin/doveadm stop (code=exited, status=0/SUCCESS)
Process: 8942 ExecStart=/usr/sbin/dovecot (code=exited, status=89)
Main PID: 8277 (code=exited, status=0/SUCCESS)
Aug 28 19:57:36 server.on3w-isp.tk systemd[1]: Stopped Dovecot IMAP/POP3 email server.
Aug 28 19:57:36 server.on3w-isp.tk systemd[1]: Starting Dovecot IMAP/POP3 email server…
Aug 28 19:57:36 server.on3w-isp.tk dovecot[8942]: doveconf: Fatal: Error in configuration file /etc/dovecot/dovecot.conf line 8: ssl_cert: Can’t open file /etc/postfix/smtpd.cert: No such file or directory
Aug 28 19:57:36 server.on3w-isp.tk systemd[1]: dovecot.service: Control process exited, code=exited status=89
Aug 28 19:57:36 server.on3w-isp.tk systemd[1]: Failed to start Dovecot IMAP/POP3 email server.
Aug 28 19:57:36 server.on3w-isp.tk systemd[1]: dovecot.service: Unit entered failed state.
Aug 28 19:57:36 server.on3w-isp.tk systemd[1]: dovecot.service: Failed with result ‘exit-code’.
root@server:/etc/postfix# nano /etc/dovecot/dovecot.conf
Active: active (running) since Wed 2019-08-28 20:00:06 UTC; 8s ago
Process: 9334 ExecStart=/usr/sbin/dovecot (code=exited, status=0/SUCCESS)
Main PID: 9337 (dovecot)
Tasks: 4
Memory: 1.6M
CPU: 16ms
CGroup: /system.slice/dovecot.service
├─9337 /usr/sbin/dovecot
├─9338 dovecot/anvil
├─9339 dovecot/log
└─9341 dovecot/config
Aug 28 20:00:06 server.on3w-isp.tk systemd[1]: Starting Dovecot IMAP/POP3 email server…
Aug 28 20:00:06 server.on3w-isp.tk systemd[1]: dovecot.service: PID file /var/run/dovecot/master.pid not readable (yet?) after start: No such file or directory
Aug 28 20:00:06 server.on3w-isp.tk dovecot[9337]: master: Dovecot v2.2.22 (fe789d2) starting up for imap, pop3 (core dumps disabled)
Aug 28 20:00:06 server.on3w-isp.tk systemd[1]: Started Dovecot IMAP/POP3 email server.
The panel Not work https://server.on3w-isp.tk:8080/login/
And my host in apache rename for 000-… 000-apps.vhost 000-default.conf 000-ispconfig.conf … All Files
And detail, that my https://server.on3w-isp.tk/phpmyadmin/ and normal https://server.on3w-isp.tk i have the SSL work. Just with port 8080 not work nothing. :confused:
and i have this error now>>> systemctl status apache2.service
● apache2.service - LSB: Apache2 web server
Loaded: loaded (/etc/init.d/apache2; bad; vendor preset: enabled)
Drop-In: /lib/systemd/system/apache2.service.d
└─apache2-systemd.conf
Active: failed (Result: exit-code) since Wed 2019-08-28 20:46:47 UTC; 3min 35s ago
Docs: man:systemd-sysv-generator(8)
Process: 11805 ExecStop=/etc/init.d/apache2 stop (code=exited, status=0/SUCCESS)
Process: 12641 ExecStart=/etc/init.d/apache2 start (code=exited, status=1/FAILURE)
Aug 28 20:46:47 server.on3w-isp.tk apache2[12641]: Output of config test was:
Aug 28 20:46:47 server.on3w-isp.tk apache2[12641]: AH00548: NameVirtualHost has no effect and will be removed in the next release /etc/apache2/sites-enabled/000-ispconfig.conf:73
Aug 28 20:46:47 server.on3w-isp.tk apache2[12641]: AH00526: Syntax error on line 63 of /etc/apache2/sites-enabled/000-ispconfig.vhost:
Aug 28 20:46:47 server.on3w-isp.tk apache2[12641]: SSLCertificateFile: file ‘/etc/letsencrypt/live/on3w-isp.tk/ispserver.crt’ does not exist or is empty
Aug 28 20:46:47 server.on3w-isp.tk apache2[12641]: Action ‘configtest’ failed.
Aug 28 20:46:47 server.on3w-isp.tk apache2[12641]: The Apache error log may have more information.
Aug 28 20:46:47 server.on3w-isp.tk systemd[1]: apache2.service: Control process exited, code=exited status=1
Aug 28 20:46:47 server.on3w-isp.tk systemd[1]: Failed to start LSB: Apache2 web server.
Aug 28 20:46:47 server.on3w-isp.tk systemd[1]: apache2.service: Unit entered failed state.
Aug 28 20:46:47 server.on3w-isp.tk systemd[1]: apache2.service: Failed with result ‘exit-code’.
Resolvido! Resolvido!
Hello o am use LE4ISPC and work fone in server admin. the problem with other tuto, is the keys not is valid i am back the backup and o do with LE4ISPC and work, but the phpmyadmin not work. :stuck_out_tongue:
@BarbaraEster
I am so happy for you! :tada:
Phpmyadmin not working is ok, you’ll get there. :slight_smile:
you can help me with this?
I see that sub.dominio.com/phpmyadmin not work
but dominio.com/phpmyadmin work for me. Oo
