I recently set up a server following the perfect server guide for Debian Jessia and ISPconfig 3.1.
It's running on a banana pi m3 with Debian jessie.
I am hosting 3 domains
matthewobrn.com
meldp.com.au
The webserver is apach2
The operating system is debian jessie
I can log into the console and run sudo commands.
I have also tested this toutorial on a fresh Vmware workstation and it worked successfully.
I have also posted the letsencrypt.log
2016-08-29 07:25:14,645:DEBUG:certbot.main:Root logging level set at 30
2016-08-29 07:25:14,649:INFO:certbot.main:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2016-08-29 07:25:14,653:WARNING:certbot.cli:You are running with an old copy of letsencrypt-auto that does not receive updates, and is less reliable than more recent versions. We recommend upgrading to the latest certbot-auto script, or using native OS packages.
2016-08-29 07:25:14,653:DEBUG:certbot.main:certbot version: 0.8.1
2016-08-29 07:25:14,654:DEBUG:certbot.main:Arguments: ['-n', '--text', '--agree-tos', '--expand', '--authenticator', 'webroot', '--server', 'https://acme-v01.api.letsencrypt.org/directory', '--rsa-key-size', '4096', '--email', 'postmaster@meldp.com.au', '--domains', 'meldp.com.au', '--webroot-path', '/usr/local/ispconfig/interface/acme']
2016-08-29 07:25:14,658:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#webroot,PluginEntryPoint#null,PluginEntryPoint#manual,PluginEntryPoint#standalone)
2016-08-29 07:25:14,660:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2016-08-29 07:25:14,680:DEBUG:certbot.plugins.selection:Single candidate plugin: * webroot
Description: Place files in webroot directory
Entry point: webroot = certbot.plugins.webroot:Authenticator
Initialized: <certbot.plugins.webroot.Authenticator object at 0xb5f90910>
Prep: True
2016-08-29 07:25:14,685:DEBUG:certbot.plugins.selection:Selected authenticator <certbot.plugins.webroot.Authenticator object at 0xb5f90910> and installer None
2016-08-29 07:25:16,155:DEBUG:certbot.main:Picked account: <Account(a855594acdf72a1943c9b2d685c6479c)>
2016-08-29 07:25:16,165:DEBUG:root:Sending GET request to https://acme-v01.api.letsencrypt.org/directory. args: (), kwargs: {}
2016-08-29 07:25:16,183:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-v01.api.letsencrypt.org
2016-08-29 07:25:18,519:DEBUG:requests.packages.urllib3.connectionpool:"GET /directory HTTP/1.1" 200 280
2016-08-29 07:25:18,525:DEBUG:root:Received <Response [200]>. Headers: {'Content-Length': '280', 'Expires': 'Mon, 29 Aug 2016 07:25:18 GMT', 'Boulder-Request-Id': 'IDcRIbDXtkzeYgjVIybhMG4IMRge7zzQTWJTw3jeIpI', 'Strict-Transport-Security': 'max-age=604800', 'Server': 'nginx', 'Connection': 'keep-alive', 'Pragma': 'no-cache', 'Cache-Control': 'max-age=0, no-cache, no-store', 'Date': 'Mon, 29 Aug 2016 07:25:18 GMT', 'X-Frame-Options': 'DENY', 'Content-Type': 'application/json', 'Replay-Nonce': 'rMtFHDLS_dY8QqibGeO4oHApq-CGsTdo7uN3b0fhlxA'}. Content: '{\n "new-authz": "https://acme-v01.api.letsencrypt.org/acme/new-authz",\n "new-cert": "https://acme-v01.api.letsencrypt.org/acme/new-cert",\n "new-reg": "https://acme-v01.api.letsencrypt.org/acme/new-reg",\n "revoke-cert": "https://acme-v01.api.letsencrypt.org/acme/revoke-cert"\n}'
2016-08-29 07:25:18,527:DEBUG:acme.client:Received response <Response [200]> (headers: {'Content-Length': '280', 'Expires': 'Mon, 29 Aug 2016 07:25:18 GMT', 'Boulder-Request-Id': 'IDcRIbDXtkzeYgjVIybhMG4IMRge7zzQTWJTw3jeIpI', 'Strict-Transport-Security': 'max-age=604800', 'Server': 'nginx', 'Connection': 'keep-alive', 'Pragma': 'no-cache', 'Cache-Control': 'max-age=0, no-cache, no-store', 'Date': 'Mon, 29 Aug 2016 07:25:18 GMT', 'X-Frame-Options': 'DENY', 'Content-Type': 'application/json', 'Replay-Nonce': 'rMtFHDLS_dY8QqibGeO4oHApq-CGsTdo7uN3b0fhlxA'}): '{\n "new-authz": "https://acme-v01.api.letsencrypt.org/acme/new-authz",\n "new-cert": "https://acme-v01.api.letsencrypt.org/acme/new-cert",\n "new-reg": "https://acme-v01.api.letsencrypt.org/acme/new-reg",\n "revoke-cert": "https://acme-v01.api.letsencrypt.org/acme/revoke-cert"\n}'
2016-08-29 07:25:18,534:DEBUG:root:Requesting fresh nonce
2016-08-29 07:25:18,535:DEBUG:root:Sending HEAD request to https://acme-v01.api.letsencrypt.org/acme/new-authz. args: (), kwargs: {}
2016-08-29 07:25:19,059:DEBUG:requests.packages.urllib3.connectionpool:"HEAD /acme/new-authz HTTP/1.1" 405 0
2016-08-29 07:25:19,061:DEBUG:root:Received <Response [405]>. Headers: {'Content-Length': '91', 'Pragma': 'no-cache', 'Boulder-Request-Id': 'u1ftQXmoqyW78yTFzK35gbpb_7R6aKNAqIcxtsuYsnY', 'Expires': 'Mon, 29 Aug 2016 07:25:18 GMT', 'Server': 'nginx', 'Connection': 'keep-alive', 'Allow': 'POST', 'Cache-Control': 'max-age=0, no-cache, no-store', 'Date': 'Mon, 29 Aug 2016 07:25:18 GMT', 'Content-Type': 'application/problem+json', 'Replay-Nonce': 'm_2v14yrip7kTK4CHhpxTHSVR0vu3cxqYV4EojxjJtY'}. Content: ''
2016-08-29 07:25:19,062:DEBUG:acme.client:Storing nonce: '\x9b\xfd\xaf\xd7\x8c\xab\x8a\x9e\xe4L\xae\x02\x1e\x1aqLt\x95GK\xee\xdd\xccja^\x04\xa2<c&\xd6'
2016-08-29 07:25:19,067:DEBUG:acme.jose.json_util:Omitted empty fields: combinations=None, expires=None, status=None, challenges=None
2016-08-29 07:25:19,068:DEBUG:acme.client:Serialized JSON: {"identifier": {"type": "dns", "value": "meldp.com.au"}, "resource": "new-authz"}
2016-08-29 07:25:19,089:DEBUG:acme.jose.json_util:Omitted empty fields: x5u=None, x5c=(), crit=(), cty=None, x5tS256=None, jku=None, alg=None, jwk=None, kid=None, x5t=None, typ=None
2016-08-29 07:25:19,353:DEBUG:acme.jose.json_util:Omitted empty fields: x5u=None, x5c=(), crit=(), cty=None, x5tS256=None, jku=None, nonce=None, typ=None, kid=None, x5t=None
2016-08-29 07:25:19,355:DEBUG:root:Sending POST request to https://acme-v01.api.letsencrypt.org/acme/new-authz. args: (), kwargs: {'data': '{"header": {"alg": "RS256", "jwk": {"e": "AQAB", "kty": "RSA", "n": "wETE-IQTch3Hr5OBSedsHJnrHHJZbSRbDazL1U_r-2IqifdURsBzi6RryyW8GqjLfSTMTrpnwTppt7NQIWZRoFr3VvjMCF35QOV6pSrSoTVmyW6JyCe_m8OIEfDA8s3mui79YZqGlC2UnPeCLiaN8ksVUFQN1RP0SVyRaUMni4I6CrCBbafwaKNxRfhNzfLqGAO7vbw_Ddcj-qw32Y-WT0BO3931WciKN0bYPoWHRpIe6oNXBy4EXYYoUxKjNhmr7uhZUIylwdPIJqf26iIIGe6o54UYVYuMCQqOy7mt6CVtB8quTDp4n1EGFQqATCSIIQrmTzWMgA3kWKBUvxpgM4JndKqAZ0yG7u-GJtHfGu0RMtlS8nkQK6_-VyuiNj7n9WeuiY5ofiUzyUeAQSc3cxZOKfZN2sAMPZ0mNeWZ2ewUx9Hr3hVPHei_jmdNRXnfog08sNlktVCNGGQgNO0WURBr8oYI7QFUTYM2cAwCZYabctWixLxKIiRGl2soBQHilP5AnfNGjw0xmgcSgbmyurWUMFQwwaIEcZs36akJ3oHw8773ZI5hyXAUxCaQbZr1l4ITRAxWO85gusyQrkhmAf_ByXeZDdbFbtE2ZnP4euKONfEqzjapnWCKiAINLD2HhF9FG_gpNI86DzMilvfAuelBif8wJLe4V4hxpTxo-VM"}}, "protected": "eyJub25jZSI6ICJtXzJ2MTR5cmlwN2tUSzRDSGhweFRIU1ZSMHZ1M2N4cVlWNEVvanhqSnRZIn0", "payload": "eyJpZGVudGlmaWVyIjogeyJ0eXBlIjogImRucyIsICJ2YWx1ZSI6ICJtZWxkcC5jb20uYXUifSwgInJlc291cmNlIjogIm5ldy1hdXRoeiJ9", "signature": "Q53BZliKFQJoR96df5WAzp_2lpZxTXIp_76bETKS2orf0_7al_TloNJrdNRCm3Jm880EYc1B0rby9Ge3IVjZwt9OtIKF6rZNpmo6tI84pnMv92zrhxUc-Z28DlsMp_anKYdZpGVJvuNGiV48w6tTwKUwI9626UKaYzMOakf-HJB-mDHJo-WmnQf4004GCKDRJyy7A-U1d54A7aBTQPGdJA4-yHor-DtsybPnV6Jmpry_xtODSdjDxohDZAPCD8XRUNByJqmpjCllr36kWcDUPLQ6S9asnI9-AbQKwtz0stsHF-iqcrAotTX_f82UtzOq64iIOeuc3Efbb6anJSLi03Z-WnYJJnZQR4BZqVk9KGQK4eSuTMW8HcQATbOTBRb8RVilz5KJEfSn9jCtjrz1TlQ6nOnUysr7vjaWDJ2ePJFrNkGqM5sbdnBpnVCCXaT8HpIUZUOZwZaLq_1RIo-WX9I0-ylxhDj1FwPDG8VmkWYWTb-gZ-W1QlxpQXyb0w1iAz_qPDieixEI_enPKo0kX0lkb2zaIsknnGwMl7UF-NVNrgFGPP9djMIBdC583WFToJGO1Ig3PBFA9-2riRmiTIxHvwldzuhUI8sxAtGV0YgeNFE98FPOKDggL-p0LAlQ477yuogjwxdLJrHcnIJWIbB2gS2d4xmnAQrMpJSv9Og"}'}
2016-08-29 07:25:19,932:DEBUG:requests.packages.urllib3.connectionpool:"POST /acme/new-authz HTTP/1.1" 201 997
2016-08-29 07:25:19,938:DEBUG:root:Received <Response [201]>. Headers: {'Content-Length': '997', 'Expires': 'Mon, 29 Aug 2016 07:25:19 GMT', 'Boulder-Request-Id': 'R2S_rk18Dm3AyYCeHFkGeXhR5gRZorq62Os3lfhlmVE', 'Strict-Transport-Security': 'max-age=604800', 'Server': 'nginx', 'Cache-Control': 'max-age=0, no-cache, no-store', 'Connection': 'keep-alive', 'Link': 'https://acme-v01.api.letsencrypt.org/acme/new-cert;rel="next"', 'Location': 'https://acme-v01.api.letsencrypt.org/acme/authz/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I', 'Pragma': 'no-cache', 'Boulder-Requester': '3729492', 'Date': 'Mon, 29 Aug 2016 07:25:19 GMT', 'X-Frame-Options': 'DENY', 'Content-Type': 'application/json', 'Replay-Nonce': 'u7TEraXEt0Gp1Xf2UAcA8h9JAXAvaYc8HWhavqfGR0Q'}. Content: '{\n "identifier": {\n "type": "dns",\n "value": "meldp.com.au"\n },\n "status": "pending",\n "expires": "2016-09-05T07:25:19.649370797Z",\n "challenges": [\n {\n "type": "dns-01",\n "status": "pending",\n "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496876",\n "token": "z-NA9Wx7Uhnia6tBQiswsGjLqR0c61wPaxTbJHgXRqI"\n },\n {\n "type": "http-01",\n "status": "pending",\n "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496877",\n "token": "OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk"\n },\n {\n "type": "tls-sni-01",\n "status": "pending",\n "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496878",\n "token": "t1sCW87cCJ92zOk4ThR_ucOdutYwnG3Q2jguVBCwap8"\n }\n ],\n "combinations": [\n [\n 0\n ],\n [\n 1\n ],\n [\n 2\n ]\n ]\n}'
2016-08-29 07:25:19,940:DEBUG:acme.client:Storing nonce: '\xbb\xb4\xc4\xad\xa5\xc4\xb7A\xa9\xd5w\xf6P\x07\x00\xf2\x1fI\x01p/i\x87<\x1dhZ\xbe\xa7\xc6GD'
2016-08-29 07:25:19,941:DEBUG:acme.client:Received response <Response [201]> (headers: {'Content-Length': '997', 'Expires': 'Mon, 29 Aug 2016 07:25:19 GMT', 'Boulder-Request-Id': 'R2S_rk18Dm3AyYCeHFkGeXhR5gRZorq62Os3lfhlmVE', 'Strict-Transport-Security': 'max-age=604800', 'Server': 'nginx', 'Cache-Control': 'max-age=0, no-cache, no-store', 'Connection': 'keep-alive', 'Link': 'https://acme-v01.api.letsencrypt.org/acme/new-cert;rel="next"', 'Location': 'https://acme-v01.api.letsencrypt.org/acme/authz/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I', 'Pragma': 'no-cache', 'Boulder-Requester': '3729492', 'Date': 'Mon, 29 Aug 2016 07:25:19 GMT', 'X-Frame-Options': 'DENY', 'Content-Type': 'application/json', 'Replay-Nonce': 'u7TEraXEt0Gp1Xf2UAcA8h9JAXAvaYc8HWhavqfGR0Q'}): '{\n "identifier": {\n "type": "dns",\n "value": "meldp.com.au"\n },\n "status": "pending",\n "expires": "2016-09-05T07:25:19.649370797Z",\n "challenges": [\n {\n "type": "dns-01",\n "status": "pending",\n "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496876",\n "token": "z-NA9Wx7Uhnia6tBQiswsGjLqR0c61wPaxTbJHgXRqI"\n },\n {\n "type": "http-01",\n "status": "pending",\n "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496877",\n "token": "OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk"\n },\n {\n "type": "tls-sni-01",\n "status": "pending",\n "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496878",\n "token": "t1sCW87cCJ92zOk4ThR_ucOdutYwnG3Q2jguVBCwap8"\n }\n ],\n "combinations": [\n [\n 0\n ],\n [\n 1\n ],\n [\n 2\n ]\n ]\n}'
2016-08-29 07:25:19,947:DEBUG:acme.challenges:dns-01 was not recognized, full message: {u'status': u'pending', u'token': u'z-NA9Wx7Uhnia6tBQiswsGjLqR0c61wPaxTbJHgXRqI', u'type': u'dns-01', u'uri': u'https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496876'}
2016-08-29 07:25:19,952:INFO:certbot.auth_handler:Performing the following challenges:
2016-08-29 07:25:19,954:INFO:certbot.auth_handler:http-01 challenge for meldp.com.au
2016-08-29 07:25:19,955:INFO:certbot.plugins.webroot:Using the webroot path /usr/local/ispconfig/interface/acme for all unmatched domains.
2016-08-29 07:25:19,956:DEBUG:certbot.plugins.webroot:Creating root challenges validation dir at /usr/local/ispconfig/interface/acme/.well-known/acme-challenge
2016-08-29 07:25:20,015:DEBUG:certbot.plugins.webroot:Attempting to save validation to /usr/local/ispconfig/interface/acme/.well-known/acme-challenge/OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk
2016-08-29 07:25:20,018:INFO:certbot.auth_handler:Waiting for verification...
2016-08-29 07:25:20,019:DEBUG:acme.client:Serialized JSON: {"keyAuthorization": "OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk.ppqvRBIqymhB47y8oHjEu7JoZG2DXBEc0fZH3z2Rzdk", "type": "http-01", "resource": "challenge"}
2016-08-29 07:25:20,039:DEBUG:acme.jose.json_util:Omitted empty fields: x5u=None, x5c=(), crit=(), cty=None, x5tS256=None, jku=None, alg=None, jwk=None, kid=None, x5t=None, typ=None
2016-08-29 07:25:20,304:DEBUG:acme.jose.json_util:Omitted empty fields: x5u=None, x5c=(), crit=(), cty=None, x5tS256=None, jku=None, nonce=None, typ=None, kid=None, x5t=None
2016-08-29 07:25:20,306:DEBUG:root:Sending POST request to https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496877. args: (), kwargs: {'data': '{"header": {"alg": "RS256", "jwk": {"e": "AQAB", "kty": "RSA", "n": "wETE-IQTch3Hr5OBSedsHJnrHHJZbSRbDazL1U_r-2IqifdURsBzi6RryyW8GqjLfSTMTrpnwTppt7NQIWZRoFr3VvjMCF35QOV6pSrSoTVmyW6JyCe_m8OIEfDA8s3mui79YZqGlC2UnPeCLiaN8ksVUFQN1RP0SVyRaUMni4I6CrCBbafwaKNxRfhNzfLqGAO7vbw_Ddcj-qw32Y-WT0BO3931WciKN0bYPoWHRpIe6oNXBy4EXYYoUxKjNhmr7uhZUIylwdPIJqf26iIIGe6o54UYVYuMCQqOy7mt6CVtB8quTDp4n1EGFQqATCSIIQrmTzWMgA3kWKBUvxpgM4JndKqAZ0yG7u-GJtHfGu0RMtlS8nkQK6_-VyuiNj7n9WeuiY5ofiUzyUeAQSc3cxZOKfZN2sAMPZ0mNeWZ2ewUx9Hr3hVPHei_jmdNRXnfog08sNlktVCNGGQgNO0WURBr8oYI7QFUTYM2cAwCZYabctWixLxKIiRGl2soBQHilP5AnfNGjw0xmgcSgbmyurWUMFQwwaIEcZs36akJ3oHw8773ZI5hyXAUxCaQbZr1l4ITRAxWO85gusyQrkhmAf_ByXeZDdbFbtE2ZnP4euKONfEqzjapnWCKiAINLD2HhF9FG_gpNI86DzMilvfAuelBif8wJLe4V4hxpTxo-VM"}}, "protected": "eyJub25jZSI6ICJ1N1RFcmFYRXQwR3AxWGYyVUFjQThoOUpBWEF2YVljOEhXaGF2cWZHUjBRIn0", "payload": "eyJrZXlBdXRob3JpemF0aW9uIjogIk9KR1NMaDkxS2d0SkIzRlBpQjl2b1hvbmlkbzUzV0dSRExPbTJuanhBbGsucHBxdlJCSXF5bWhCNDd5OG9IakV1N0pvWkcyRFhCRWMwZlpIM3oyUnpkayIsICJ0eXBlIjogImh0dHAtMDEiLCAicmVzb3VyY2UiOiAiY2hhbGxlbmdlIn0", "signature": "isoEzF9Mxr_DhZsAImP8DDn3QfUU6G7jKJ96CBX7maYDAvAaUijq7M6WojFefe_ARvwKzAvBGpl-KFXMFhm2VEWMfhttyTx3s7BH0nEqrKZk6Opic2JuIt1_z2oVoe9qOlj5lsokTFtw6P3oKFgXNuHlpxBNXj5FHUvULVjpuNAnNMwrai2i8nQrHFfm0X9WTHkfJVGDhmO6mNzlFoV80IzVVosWIOz2YBzM9uGYO27UiVOBTbOT6x_iA-Yyuj1Gmu7xtZfO56lv2yg_7xzPP1zIbQhoxq3poq8IZAxc3oP1ROx6VQPQdgBz73BxLgswTZi9jqCNPhNcehc5VfOLmaH0oj6xdxfhOfWrPhgcCsaY2U1mCxdZmRhF2BD5DKqyGvtmujbXesKP0KGaj-353--0wBRCpFxFGrHry-s-8loH8-3pqUd1Y-J8J7ULs8pQaCZ-y919CoKDmqeocVE4Ni8RjGdtl0eTrLsTK8Y9UdXg5ysv2ezOV3f0hP6TjnL5A66RZEkN-BqwV6MArft_w3FANgIz2BtrzJddfJ_v2dmpolHwCuefR9UVZN09sAMD5TnurYwz0yfOSo5MDl_m4OwR6waqRiIMRvUHy464okiEh93_CzyL6WBUmTAA8VDYFsEoZOOue7yM9aJt-AmR5Rtn778dImJ1bCD23iPzs7I"}'}
2016-08-29 07:25:20,870:DEBUG:requests.packages.urllib3.connectionpool:"POST /acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496877 HTTP/1.1" 202 335
2016-08-29 07:25:20,873:DEBUG:root:Received <Response [202]>. Headers: {'Content-Length': '335', 'Boulder-Request-Id': 'PjcTY2raGcSkJPYfSPCXi_Fv8RMAlpMK05KCLctL4Ec', 'Expires': 'Mon, 29 Aug 2016 07:25:20 GMT', 'Server': 'nginx', 'Cache-Control': 'max-age=0, no-cache, no-store', 'Connection': 'keep-alive', 'Link': 'https://acme-v01.api.letsencrypt.org/acme/authz/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I;rel="up"', 'Location': 'https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496877', 'Pragma': 'no-cache', 'Boulder-Requester': '3729492', 'Date': 'Mon, 29 Aug 2016 07:25:20 GMT', 'Content-Type': 'application/json', 'Replay-Nonce': 'AtezvV0S9Ka62CXcuXK1AXcZW6nb1avwI2UyaS_ShA0'}. Content: '{\n "type": "http-01",\n "status": "pending",\n "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496877",\n "token": "OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk",\n "keyAuthorization": "OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk.ppqvRBIqymhB47y8oHjEu7JoZG2DXBEc0fZH3z2Rzdk"\n}'
2016-08-29 07:25:20,874:DEBUG:acme.client:Storing nonce: '\x02\xd7\xb3\xbd]\x12\xf4\xa6\xba\xd8%\xdc\xb9r\xb5\x01w\x19[\xa9\xdb\xd5\xab\xf0#e2i/\xd2\x84\r'
2016-08-29 07:25:20,875:DEBUG:acme.client:Received response <Response [202]> (headers: {'Content-Length': '335', 'Boulder-Request-Id': 'PjcTY2raGcSkJPYfSPCXi_Fv8RMAlpMK05KCLctL4Ec', 'Expires': 'Mon, 29 Aug 2016 07:25:20 GMT', 'Server': 'nginx', 'Cache-Control': 'max-age=0, no-cache, no-store', 'Connection': 'keep-alive', 'Link': 'https://acme-v01.api.letsencrypt.org/acme/authz/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I;rel="up"', 'Location': 'https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496877', 'Pragma': 'no-cache', 'Boulder-Requester': '3729492', 'Date': 'Mon, 29 Aug 2016 07:25:20 GMT', 'Content-Type': 'application/json', 'Replay-Nonce': 'AtezvV0S9Ka62CXcuXK1AXcZW6nb1avwI2UyaS_ShA0'}): '{\n "type": "http-01",\n "status": "pending",\n "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496877",\n "token": "OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk",\n "keyAuthorization": "OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk.ppqvRBIqymhB47y8oHjEu7JoZG2DXBEc0fZH3z2Rzdk"\n}'
2016-08-29 07:25:23,880:DEBUG:root:Sending GET request to https://acme-v01.api.letsencrypt.org/acme/authz/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I. args: (), kwargs: {}
2016-08-29 07:25:24,412:DEBUG:requests.packages.urllib3.connectionpool:"GET /acme/authz/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I HTTP/1.1" 200 1837
2016-08-29 07:25:24,418:DEBUG:root:Received <Response [200]>. Headers: {'Content-Length': '1837', 'Expires': 'Mon, 29 Aug 2016 07:25:24 GMT', 'Boulder-Request-Id': '6njQZQCykeLepxUcR-yjkHaXsafVlk3el74UYshOCL8', 'Strict-Transport-Security': 'max-age=604800', 'Server': 'nginx', 'Connection': 'keep-alive', 'Link': 'https://acme-v01.api.letsencrypt.org/acme/new-cert;rel="next"', 'Pragma': 'no-cache', 'Cache-Control': 'max-age=0, no-cache, no-store', 'Date': 'Mon, 29 Aug 2016 07:25:24 GMT', 'X-Frame-Options': 'DENY', 'Content-Type': 'application/json', 'Replay-Nonce': 'mplPVtv9f7SAV6iQ5OOXQQiKS7Vrs9fJrMZuRXcFmWA'}. Content: '{\n "identifier": {\n "type": "dns",\n "value": "meldp.com.au"\n },\n "status": "invalid",\n "expires": "2016-09-05T07:25:19Z",\n "challenges": [\n {\n "type": "dns-01",\n "status": "pending",\n "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496876",\n "token": "z-NA9Wx7Uhnia6tBQiswsGjLqR0c61wPaxTbJHgXRqI"\n },\n {\n "type": "http-01",\n "status": "invalid",\n "error": {\n "type": "urn:acme:error:unauthorized",\n "detail": "Invalid response from http://meldp.com.au/.well-known/acme-challenge/OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk: \"\u003c!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\\"\\u003e\\n\\u003cht\\"",\n "status": 403\n },\n "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496877",\n "token": "OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk",\n "keyAuthorization": "OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk.ppqvRBIqymhB47y8oHjEu7JoZG2DXBEc0fZH3z2Rzdk",\n "validationRecord": [\n {\n "url": "http://meldp.com.au/.well-known/acme-challenge/OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk",\n "hostname": "meldp.com.au",\n "port": "80",\n "addressesResolved": [\n "122.151.149.134"\n ],\n "addressUsed": "122.151.149.134"\n }\n ]\n },\n {\n "type": "tls-sni-01",\n "status": "pending",\n "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496878",\n "token": "t1sCW87cCJ92zOk4ThR_ucOdutYwnG3Q2jguVBCwap8"\n }\n ],\n "combinations": [\n [\n 0\n ],\n [\n 1\n ],\n [\n 2\n ]\n ]\n}'
2016-08-29 07:25:24,421:DEBUG:acme.client:Received response <Response [200]> (headers: {'Content-Length': '1837', 'Expires': 'Mon, 29 Aug 2016 07:25:24 GMT', 'Boulder-Request-Id': '6njQZQCykeLepxUcR-yjkHaXsafVlk3el74UYshOCL8', 'Strict-Transport-Security': 'max-age=604800', 'Server': 'nginx', 'Connection': 'keep-alive', 'Link': 'https://acme-v01.api.letsencrypt.org/acme/new-cert;rel="next"', 'Pragma': 'no-cache', 'Cache-Control': 'max-age=0, no-cache, no-store', 'Date': 'Mon, 29 Aug 2016 07:25:24 GMT', 'X-Frame-Options': 'DENY', 'Content-Type': 'application/json', 'Replay-Nonce': 'mplPVtv9f7SAV6iQ5OOXQQiKS7Vrs9fJrMZuRXcFmWA'}): '{\n "identifier": {\n "type": "dns",\n "value": "meldp.com.au"\n },\n "status": "invalid",\n "expires": "2016-09-05T07:25:19Z",\n "challenges": [\n {\n "type": "dns-01",\n "status": "pending",\n "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496876",\n "token": "z-NA9Wx7Uhnia6tBQiswsGjLqR0c61wPaxTbJHgXRqI"\n },\n {\n "type": "http-01",\n "status": "invalid",\n "error": {\n "type": "urn:acme:error:unauthorized",\n "detail": "Invalid response from http://meldp.com.au/.well-known/acme-challenge/OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk: \"\u003c!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\\"\\u003e\\n\\u003cht\\"",\n "status": 403\n },\n "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496877",\n "token": "OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk",\n "keyAuthorization": "OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk.ppqvRBIqymhB47y8oHjEu7JoZG2DXBEc0fZH3z2Rzdk",\n "validationRecord": [\n {\n "url": "http://meldp.com.au/.well-known/acme-challenge/OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk",\n "hostname": "meldp.com.au",\n "port": "80",\n "addressesResolved": [\n "122.151.149.134"\n ],\n "addressUsed": "122.151.149.134"\n }\n ]\n },\n {\n "type": "tls-sni-01",\n "status": "pending",\n "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496878",\n "token": "t1sCW87cCJ92zOk4ThR_ucOdutYwnG3Q2jguVBCwap8"\n }\n ],\n "combinations": [\n [\n 0\n ],\n [\n 1\n ],\n [\n 2\n ]\n ]\n}'
2016-08-29 07:25:24,425:DEBUG:acme.challenges:dns-01 was not recognized, full message: {u'status': u'pending', u'token': u'z-NA9Wx7Uhnia6tBQiswsGjLqR0c61wPaxTbJHgXRqI', u'type': u'dns-01', u'uri': u'https://acme-v01.api.letsencrypt.org/acme/challenge/yBedDzMNZsKaaCqogY_TWCZTUkvR13uttFfFSw8Lx_I/248496876'}
2016-08-29 07:25:24,433:INFO:certbot.reporter:Reporting to user: The following errors were reported by the server:
Domain: meldp.com.au
Detail: Invalid response from http://meldp.com.au/.well-known/acme-challenge/OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk: "
<ht"
To fix these errors, please make sure that your domain name was entered correctly and the DNS A record(s) for that domain contain(s) the right IP address.
2016-08-29 07:25:24,434:INFO:certbot.auth_handler:Cleaning up challenges
2016-08-29 07:25:24,436:DEBUG:certbot.plugins.webroot:Removing /usr/local/ispconfig/interface/acme/.well-known/acme-challenge/OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk
2016-08-29 07:25:24,439:INFO:certbot.plugins.webroot:Unable to clean up challenge directory /usr/local/ispconfig/interface/acme/.well-known/acme-challenge
2016-08-29 07:25:24,440:DEBUG:certbot.plugins.webroot:Error was: [Errno 39] Directory not empty: '/usr/local/ispconfig/interface/acme/.well-known/acme-challenge'
2016-08-29 07:25:24,458:DEBUG:certbot.main:Exiting abnormally:
File "/root/.local/share/letsencrypt/bin/letsencrypt", line 11, in
sys.exit(main())
File "/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/main.py", line 744, in main
File "/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/main.py", line 555, in obtain_cert
_, action = _auth_from_domains(le_client, config, domains, lineage)
File "/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/main.py", line 94, in _auth_from_domains
lineage = le_client.obtain_and_enroll_certificate(domains)
File "/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/client.py", line 276, in obtain_and_enroll_certificate
certr, chain, key, _ = self.obtain_certificate(domains)
File "/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/client.py", line 247, in obtain_certificate
self.config.allow_subset_of_names)
File "/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 74, in get_authorizations
self._respond(resp, best_effort)
File "/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 131, in _respond
self._poll_challenges(chall_update, best_effort)
File "/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 195, in _poll_challenges
raise errors.FailedChallenges(all_failed_achalls)
FailedChallenges: Failed authorization procedure. meldp.com.au (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://meldp.com.au/.well-known/acme-challenge/OJGSLh91KgtJB3FPiB9voXonido53WGRDLOm2njxAlk: "
<ht"
