I have ISPCONFIG on Debian 8. I installed this type of configuration following the instruction of ISPCONFIG perfect server with the purpose to automatise also the renewal of Let’s Encypy certificate.
**I received the message of expiry for domain welcometoparma.eu and i was questioning about auto-renew features of ispconfig. **
The great @serverco tells me that if autorenewal from ispconfig doesn’t work i had to use command-line. So today the last day useful to renw i do it like written in this official guide:
https://certbot.eff.org/all-instructions/
"Automating renewal
Certbot can be configured to renew your certificates automatically before they expire. Since Let’s Encrypt certificates last for 90 days, it’s highly advisable to take advantage of this feature. You can test automatic renewal for your certificates by running this command:
./path/to/certbot-auto renew --dry-run
If that appears to be working correctly, you can arrange for automatic renewal by adding a cron or systemd job which runs the following:
./path/to/certbot-auto renew --no-self-upgrade
More detailed information and options about renewal can be found in the full documentation.
Note:
if you’re setting up a cron or systemd job, we recommend running it twice per day (it won’t do anything until your certificates are due for renewal or revoked, but running it regularly would give your site a chance of staying online in case a Let’s Encrypt-initiated revocation happened for some reason). Please select a random minute within the hour for your renewal tasks"
I’ve done it but the result is:
"The following certs could not be renewed:
/etc/letsencrypt/live/domain2.com/fullchain.pem (failure)
Domain: www.domain2.com
Detail: Incorrect validation certificate for tls-sni-01 challenge.
Requested
df1e057d2b230fcc317ae05a220e13d4.ccaad77e143d0b2f9c16ea2f813c571a.acme.invalid
from 94.28.3.195:443. Received 2 certificate(s), first certificate
had names “domain1.om, www.domain1.com”Domain: domain2.com
Requested
d8d3f0e75ecfda1d5c32e4fe4197f871.cd5be13c5686d076da49acc4493e095b.acme.invalid
had names “domain1.com, www.domain1.com”To fix these errors, please make sure that your domain name was
contain(s) the right IP address. -
Your account credentials have been saved in your Certbot
making regular backups of this folder is ideal."
So what can i do? The time is passing and i don’t understand what to do, all is configured with ISPCONFIG but if ISPCONFIG fails… i’ve a lot of domain on that machines…
Try checking at
