Can you show me the exact commands you used to issue the certificate for dominio.com
with the LE4ISPC tool?
Here>>>
cd /etc/ssl
wget https://raw.githubusercontent.com/ahrasis/LE4ISPC/master/le4ispc.sh --no-check-certificate
chmod +x le4ispc.sh
./le4ispc.sh
and create the cert in >>/etc/letsencrypt/live
ispvultr.tk and server.ispvultr.tk
Thx
I have this files in folders>
cert.pem chain.pem fullchain.pem privkey.pem README
The LE4ISPC is trying to be clever just like the initial tutorial you followed weeks ago.
I can see that the certificate being served by server.ispvultr.tk is only valid for ispvultr.tk which means your server hostname is probably ispvultr.tk
$ echo | openssl s_client -connect server.ispvultr.tk:443 -servername server.ispvultr.tk 2> /dev/null | openssl x509 -noout -issuer -subject -startdate -enddate
issuer=C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3
subject=CN = ispvultr.tk
notBefore=Sep 10 18:52:11 2019 GMT
notAfter=Dec 9 18:52:11 2019 GMT
$ echo | openssl s_client -connect ispvultr.tk:443 -servername ispvultr.tk 2> /dev/null | openssl x509 -noout -issuer -subject -startdate -enddate
Can you run this command and show me the output please?
hostname -f
Before I can provide you with an actual solution, I’d need to play with ISP Config and that LE4ISPC script. Otherwise you’d have to alter some of the functionality yourself. I don’t have an answer for when I’ll be able to do that.
The important lines to note are https://github.com/ahrasis/LE4ISPC/blob/master/le4ispc.sh#L20 and https://github.com/ahrasis/LE4ISPC/blob/master/le4ispc.sh#L28.
Here>>>
root@server:~# hostname -f
server.ispvultr.tk
I am not able to help with the ISPConfig part but I wanted to point out that the --no-check-certificate
option for wget
is rather dangerous, especially in this case where you are downloading software that you're going to run. Did you find a tutorial that suggested using this option with wget
in this situation?
Yes this command is tutorial for install the Lets a plugin for this . The code here>>>
Thanks! I’ll suggest that the author change that recommendation in the tutorial.
Edit: suggested at
i understand, you talk me the best.
Very thanks!!!
xD, you know the motive for contraditorie situation in url? In phpmyadmin.
Thx for Edit code for the best.
