Cant create letsencrypt for website with ispconfig panel
My domain is: test.pangandarankab.go.id
My web server is (include version): apache2
The operating system my web server runs on is (include version): Debian 10
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): ISPConfig Version: 3.2.11p2
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.31.0
My problem is when I check on the letsencrypt ssl button, the button again becomes unchecked. Help me to fix that please :frowning:
Please help us by not removing questions from the questionnaire, especially the output question.
I'm so sorry sir, I'm newbie here
Your site is working with HTTPS and a cert you got today.
If you still have a problem can you explain in more words what is wrong? See the below two SSL test sites that show your site using a recent cert correctly
https://www.ssllabs.com/ssltest/analyze.html?d=test.pangandarankab.go.id&hideResults=on&latest
Yes SIr, I don't know why it works, but my other website (percobaan.pangandarankab.go.id) now can't use letsencrypt ssl, after I do a check on the button letsencrypt ssl always changes to unchecked. my other website uses a different public IP
Was it ever able to get a certificate?
Usually you have to run a program (like ispconfig or certbot) on each server to get a cert on that server. I am not expert with ispconfig so maybe it has advanced options.
Getting a cert with ispconfig on one server should not affect getting a cert on another server.
Did you setup ispconfig or was that provided by a hosting service?
On another virtual server I was previously able to get a certificate pack, as does the website test.pangandarankab.go.id. but now I try on another virtual server that contains the website percobaan.pangandarankab.go.id with a different public ip I can't get the certificate, I've added a public ip on the DNS service I have (cloudflare).
Yes sir I installed ispconfig panel myself because previously not available any panel, only provided Debian OS 10
Is there a log that has error messages on why the cert was not issued? You haven't given us much info to work with.
And, it sounds like a problem with the ISPconfig or server configuration. Have you tried asking about this on the ISPconfig community forum? People there are more familiar with using it and how to debug its problems.
I am trying to create certbot manually with the following code sir
sudo certbot certonly --webroot -w /var/www/clients/client0/web3/ssll -d percobaan.pangandarankab.go.id
No sir, I have not asked the ispconfig community
The percoban domain is proxied at Cloudflare so is using its CDN
The test domain you showed earlier is NOT proxied and the DNS points directly to the IP for that server.
This is important difference. Setting up a server behind a CDN takes extra care. Did you proxy that domain on purpose or was it just a mistake?
nslookup percobaan.pangandarankab.go.id
A    Address: 172.67.170.114
A    Address: 104.21.95.139
AAAA Address: 2606:4700:3031::6815:5f8b
AAAA Address: 2606:4700:3035::ac43:aa72
nslookup test.pangandarankab.go.id
A    Address: 36.89.114.121
