Letsencrypt and no-ip
My domain is:footie.ddns.net:93
I ran this command:na
It produced this output:na
My web server is (include version):apache2
The operating system my web server runs on is (include version):debian buster
My hosting provider, if applicable, is:no-ip
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):na
Before I spend a lot of time maybe wasted, can you confirm that i can install letsencrypt ssl certs on my apache2 webserver with a free no-ip domain name givin me https protection. Thanks for your help...
yes, you can.
you need to control either port 80 or 443, tho. you can install the certificate on 93, but you must use 80 or 443 to perform the validation. (or use the dns challenge by adding a txt record from the no-ip interface -- but you should use a verification method that can renew your certificate without human intervention, like http-01 on port 80)
Hi, many thanks for your very quick reply. I have never done this before, are there any instructions anywhere on how to do this please (ive been on no-ip and no real help there for me). Your help is appreciated. Kind regards Don...
Here, have instructions for your software and OS: Certbot Instructions | Certbot
Top man, thanks for your help....
Hi, I get the following error:
$ sudo ln -s /snap/bin/certbot /usr/bin/certbot
ln: failed to create symbolic link '/usr/bin/certbot': File exists
The file does exist and it was created back in 2020...can I delete this file and run the command again or shall I just continue as the file does exist ?? many thanks Don...
the instructions told you to uninstall old certbots: did you?
opppps, (very red faced) ...to be honest cant ever remember installing it. Can i go back and uninstall it all and start again ?
sudo apt-get remove certbot , sudo dnf remove certbot , or sudo yum remove certbot
yes, you can.
(it's debian... so apt-get)
Uninstalled and autoreoved, rebooted but still says installed ?? Im struggling with this now..
pi@raspberrypi:~ $ sudo apt-get remove certbot
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package 'certbot' is not installed, so not removed
The following packages were automatically installed and are no longer required:
augeas-lenses libaugeas0 python-pyicu python3-acme python3-augeas
python3-certbot python3-configargparse python3-configobj python3-future
python3-josepy python3-mock python3-parsedatetime python3-pbr
python3-requests-toolbelt python3-rfc3339 python3-tz python3-zope.component
python3-zope.event python3-zope.hookable python3-zope.interface
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@raspberrypi:~ $ sudo apt-get autoremove
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 20 to remove and 0 not upgraded.
After this operation, 9,178 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 123342 files and directories currently installed.)
Removing python3-augeas (0.5.0-1) ...
Removing libaugeas0:armhf (1.11.0-3) ...
Removing augeas-lenses (1.11.0-3) ...
Removing python-pyicu (2.2-2) ...
Removing python3-certbot (0.31.0-1+deb10u1) ...
Removing python3-acme (0.31.0-2) ...
Removing python3-configargparse (0.13.0-1) ...
Removing python3-configobj (5.0.6-3) ...
Removing python3-parsedatetime (2.4-2) ...
Removing python3-future (0.16.0-1) ...
Removing python3-josepy (1.1.0-2) ...
Removing python3-mock (2.0.0-4) ...
Removing python3-pbr (4.2.0-5) ...
Removing python3-requests-toolbelt (0.8.0-1) ...
Removing python3-rfc3339 (1.1-1) ...
Removing python3-tz (2019.1-1) ...
Removing python3-zope.component (4.3.0-1) ...
Removing python3-zope.event (4.2.0-1) ...
Removing python3-zope.hookable (4.0.4-4+b3) ...
Removing python3-zope.interface (4.3.2-1+b2) ...
Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u2) ...
pi@raspberrypi:~ $ sudo snap install --classic certbot
snap "certbot" is already installed, see 'snap help refresh'
pi@raspberrypi:~ $
it looks fine. you installed it before.
OK, moving on, when it asks for the domain name do I put footie.ddns.net or footie.ddns.net:93 ? Thank you
Just remember to do the symbolic link-creation step for /usr/bin/certbot again.
Just footie.ddns.net without the port.
Also, please note that your website is reported as containing harmful content by Google:
https://transparencyreport.google.com/safe-browsing/search?url=footie.ddns.net
I did do the link creation again and it worked but!!!
Yes,that why I am trying to install SSL to stop this
2023-08-04 15:58:08,063:DEBUG:urllib3.connectionpool:http://localhost:None "GET$
2023-08-04 15:58:09,531:DEBUG:certbot._internal.main:certbot version: 2.6.0
2023-08-04 15:58:09,532:DEBUG:certbot._internal.main:Location of certbot entry $
2023-08-04 15:58:09,532:DEBUG:certbot._internal.main:Arguments: ['--apache', '-$
2023-08-04 15:58:09,533:DEBUG:certbot._internal.main:Discovered plugins: Plugin$
2023-08-04 15:58:09,606:DEBUG:certbot._internal.log:Root logging level set at 30
2023-08-04 15:58:09,609:DEBUG:certbot._internal.plugins.selection:Requested aut$
2023-08-04 15:58:09,894:DEBUG:certbot_apache._internal.configurator:Apache vers$
2023-08-04 15:58:10,799:DEBUG:certbot._internal.plugins.selection:Single candid$
Description: Apache Web Server plugin
Interfaces: Authenticator, Installer, Plugin
Entry point: apache = certbot_apache._internal.entrypoint:ENTRYPOINT
Initialized: <certbot_apache._internal.override_debian.DebianConfigurator objec$
Prep: True
2023-08-04 15:58:10,801:DEBUG:certbot._internal.plugins.selection:Selected auth$
2023-08-04 15:58:10,802:INFO:certbot._internal.plugins.selection:Plugins select$
2023-08-04 15:58:10,872:DEBUG:certbot._internal.main:Picked account: <Account(R$
2023-08-04 15:58:10,875:DEBUG:acme.client:Sending GET request to https://acme-v$
2023-08-04 15:58:10,883:DEBUG:urllib3.connectionpool:Starting new HTTPS connect$
2023-08-04 15:58:11,353:DEBUG:urllib3.connectionpool:https://acme-v02.api.letse$
2023-08-04 15:58:11,356:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Fri, 04 Aug 2023 14:58:11 GMT
Content-Length: 752
X-Frame-Options: DENY
"5mAncaJ43hI": "https://community.letsencrypt.org/t/adding-random-entries-to-$
"meta": {
"caaIdentities": [
A certificate won't matter for Google Safe Browsing.
it should've told you a lot more than this
Im panicking here...my site must have been hacked...how do I find what the problem is...
is your port 22 reachable from the internet, and are you still using "raspberry" as a password?
If so, turn everything off and start anew with another sdcard.
i dont use password raspberry and not sure how to check if paort 22 is available from the network. I just tried to connect to my public ip address with port 22 from a browser and it says site cant be reached which must be good ??
