Error first setup letsencrypt using Digital Ocean
Server version: Apache/2.4.18 (Ubuntu)
Ubuntu 16.04
Digital Ocean
I installed Certbot with (certbot-auto, OS package manager, pip, etc):
I ran this command and it produced this output:
sudo certbot --authenticator standalone --installer apache --pre-hook “systemctl stop apache2” --post-hook “systemctl start apache2”
Logs are stored in /var/log/letsencrypt by default. Feel free to redact domains, e-mail and IP addresses as you see fit.
File “/usr/lib/python2.7/dist-packages/certbot/main.py”, line 698, in run
certname, lineage)
File “/usr/lib/python2.7/dist-packages/certbot/main.py”, line 85, in _get_and_save_cert
File “/usr/lib/python2.7/dist-packages/certbot/client.py”, line 375, in obtain_and_enroll_certificate
self.config)
File “/usr/lib/python2.7/dist-packages/certbot/storage.py”, line 1019, in new_lineage
os.mkdir(live_dir)
OSError: [Errno 20] Not a directory: ‘/etc/letsencrypt/live/www.meriah.my-0002’
2018-02-05 15:00:32,837:ERROR:certbot.log:An unexpected error occurred:
Hi @KhairulAzmi21,
Did you previously change the contents of /etc/letsencrypt in some way, like by moving or renaming things there?
i dont think so . i just created droplet on DO . and follow the tutorial as above
