SSL not working on DigitalOcean
My domain is: shopitail.com
I ran this command: How To Secure Apache with Let's Encrypt on Ubuntu 18.04 | DigitalOcean
It produced this output: run successfully all the command in the above link
My web server is (include version): Ubuntu
My hosting provider, if applicable, is: digitalOcean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
Hi @mmusupp,
Welcome to the forum.
Since you mentioned you did execute all commands from the above tutorial, could you show output of the command sudo certbot certificates?
Looking at your server and logs, you did have certificate for your root domain. However, your apache webserver only listens on port 80 not port 443. You might want to check your Apache configuration and see what's wrong.
Thank you
Thank you!
Since you didn't have any certificates, can you try to run the tutorial again?
By the way, did you recreate your instance in the past days?
(Paying careful attention to the output in Step 4, where the certificate is requested from the certificate authority!)
No, i did not created.
first command output : sudo add-apt-repository ppa:certbot/certbot
@schoen this is coorect
It shows that the tutorial's advice is out-of-date, but nonetheless, this is probably not the reason for your specific problem!
I see a lot of tutorials that are obsolete. I tend to mention on my site that ideas are in FORTRAN 77 or C++11 etc so that copies are usable
other posts such as sample scripts are obsoleted by Linux changes
