First, an Apache server is listening on port 80 (and 443) so you can quit trying to use the --nginx plug-in
So, you got two certs just a couple hours ago although the only domain name in the cert is the root name. The missing www subdomain is not the biggest problem right now.
But, your server is using a cert with the allhotels.com domain (and its www subdomain). Your IP address for dailydeal.com is wrong or your Apache config is faulty. Do you recognize allhotels? Is your Apache version 2.4.18?
VirtualHost configuration:
*:443 is a NameVirtualHost
default server cheaptextbooks.com (/etc/apache2/sites-enabled/cheaptextbooks.com-le-ssl.conf:1)
port 443 namevhost cheaptextbooks.com (/etc/apache2/sites-enabled/cheaptextbooks.com-le-ssl.conf:1)
alias www.cheaptextbooks.com
port 443 namevhost dailydeal.com (/etc/apache2/sites-enabled/dailydeal.com-le-ssl.conf:1)
alias www.dailydeal.com
port 443 namevhost freeonmessagedomains.com (/etc/apache2/sites-enabled/freeonmessagedomains.com.conf:21)
alias www.freeonmessagedomains.com
port 443 namevhost namedream.com (/etc/apache2/sites-enabled/namedream.com-le-ssl.conf:1)
alias www.namedream.com
*:80 is a NameVirtualHost
default server cheaptextbooks.com (/etc/apache2/sites-enabled/cheaptextbooks.com.conf:1)
port 80 namevhost cheaptextbooks.com (/etc/apache2/sites-enabled/cheaptextbooks.com.conf:1)
port 80 namevhost dailydeal.com (/etc/apache2/sites-enabled/dailydeal.com-le-ssl.conf:25)
port 80 namevhost dailydeal.com (/etc/apache2/sites-enabled/dailydeal.com.conf:1)
port 80 namevhost freeonmessagedomains.com (/etc/apache2/sites-enabled/freeonmessagedomains.com.conf:1)
port 80 namevhost namedream.com (/etc/apache2/sites-enabled/namedream.com.conf:1)
root@Droplet5:~# service apache2 restart
root@Droplet5:~#
