I have just installed the SSL certificate and it is not working any more.
The site is redirecting to https, but not working.
Kindly help.
Kindly help.
sudo certbot --apache -d letsmuvi.com -d www.letsmuvi.com
Web Server: Apache2
It looks like this is likely to be a firewall problem because connections to TCP port 443 on your server simply time out (rather than being accepted or rejected outright), while port 80 works. This is typical of firewall problems where packets for a particular port are simply dropped.
The problem is most likely not directly with your certificate.
Not according to 3 different locations I just scanned from.
# nmap -sT -r -n -p443,80 letsmuvi.com
Starting Nmap 7.40 ( https://nmap.org ) at 2018-12-14 15:38 AEDT
Nmap scan report for letsmuvi.com (139.59.34.166)
Host is up (0.19s latency).
PORT STATE SERVICE
80/tcp open http
443/tcp filtered https
You doing some kind of geo-IP filtering?
I have still not got this resolved.
Kindly help urgently,
The cert on the site is updated.
What problem remains?
