Redirect to https not working + error when forcing
My domain is:www.raidatrades.com
I ran this command:certbot SSL
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/raidatrades.com/fullchain.pem
/etc/letsencrypt/live/raidatrades.com/privkey.pem
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains: https://raidatrades.com and
https://www.raidatrades.com
My web server is (include version):Apache2
The operating system my web server runs on is (include version):Ubuntu 18.04 LTS
My hosting provider, if applicable, is: *
I can login to a root shell on my machine (yes or no, or I don’t know):Yes
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):No
I came here because I simply cant find what the problem is. I forwarded port 443 for SSL, which is open as the open port tool describes. I ran the certbot without any problems for apache2.
But the redirect is not working. I tried redirecting manually with a .htacces file, that worked BUT: the browser says that my site can not establish a secure connection. This is true on multiple devices.
It also gives a ERR_SSL_PROTOCOL_ERROR when i try to connect to my site with https.
Listening ports :
tcp6 0 0 :::80 :::* LISTEN 7201/apache2
tcp6 0 0 :::443 :::* LISTEN 7201/apache2
my ufw firewall allows everything coming in and out for apache2.
My virtual host file looks like this :
Normal ( port 80 )
<VirtualHost 94.110.172.188:80>
# specifies what hostname must appear in the request’s Host: header to
#ServerName www.example.com
    ServerAdmin raida@raidatrades.com
    DocumentRoot /var/www/html/
    Redirect permanent /secure https://raidatrades.com/secure
    ServerName raidatrades.com
    ServerAlias www.raidatrades.com
    # error, crit, alert, emerg.
    # modules, e.g.
    #LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =raidatrades.com [OR]
RewriteCond %{SERVER_NAME} =www.raidatrades.com
vim: syntax=apache ts=4 sw=4 sts=4 sr noet
SSL file ( port 443 )
# The ServerName directive sets the request scheme, hostname and port that # the server uses to identify itself. This is used when creating # redirection URLs. In the context of virtual hosts, the ServerName # specifies what hostname must appear in the request's Host: header to # match this virtual host. For the default virtual host (this file) this # value is not decisive as it is used as a last resort host regardless. # However, you must set it for any further virtual host explicitly. #ServerName www.example.com
    SSLEngine On
    # modules, e.g.
RewriteEngine on
Some rewrite rules in this file were disabled on your HTTPS site,
because they have the potential to create redirection loops.
SSLCertificateFile /etc/letsencrypt/live/raidatrades.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/raidatrades.com/privkey.pem
If you need anything more please just say so, i’m literally breaking my head for days why this simple thing just won’t work. I’m losing my mind.
Apache is listening with regular insecure HTTP on port 443: http://www.raidatrades.com:443 . This indicates that the VirtualHost is not properly configured for HTTPS.
Typically the minimum for what is required for a VirtualHost to be picked up as HTTPS is:
SSLEngine On
<VirtualHost *:443>
    SSLCertificateFile ...
    SSLCertificateKeyFile ...
</VirtualHost>
This is the virtual host for port 443 right?
I included all of that, buit it should have been generated by certbot standard.
How do I know if this Virtual Host is ACTUALLY running? Because by the looks of it, It sure doesnt.
You can see your VirtualHost list with
apachectl -S
Well, i can't see the <VirtualHost *:443> scope in your original post, only one for port 80. Maybe you have it, maybe you don't, can't tell from here.
It also occurs to me to double check that port 443 is forwarded to port 443, in the past people have accidentally forwarded 443 externally to 80 internally, which can also manifest in these kinds of symptoms.
When I enter that command i get this error
AH00526: Syntax error on line 193 of /etc/modsecurity/modsecurity.conf:
ModSecurity: Failed to open the audit log file: /var/log/apache2/modsec_audit.log
Action '-S' failed.
I will post both virtual hosts again, maybe you can see what is wrong but I don't.
RewriteEngine on
port 443 host file :
<VirtualHost 94.110.172.188:443>
SSLEngine On
# modules, e.g.
RewriteEngine on
If your Apache config isn’t passing compilation, then it’s possible that your current config was never actually loaded.
Maybe comment out your modsec stuff until apachectl -S actually works, reload Apache, and see if that helps the issue.
Never mind, I had to run that command as root.
It gives this info
VirtualHost configuration:
94.110.172.188:80 raidatrades.com (/etc/apache2/sites-enabled/000-default.conf:1)
94.110.172.188:443 raidatrades.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
ServerRoot: “/etc/apache2”
Main DocumentRoot: “/var/www/html”
Main ErrorLog: “/var/log/apache2/error.log”
PidFile: “/var/run/apache2/apache2.pid”
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
Define: MODSEC_2.5
Define: MODSEC_2.9
User: name=“www-data” id=33
Group: name=“www-data” id=33
Seems like your site is working fine now - https://www.raidatrades.com/
If you made any changes since you posted this thread, they seem to have helped.
Oh what the heck. Ok then
The only thing I changed was changing my public ip in the port 443 host to default
and also I removed the modules in ports.conf and changed it to
Listen 80
Listen 443 https
Seems like that did the trick? I’m not sure.
Anyways thank you !
Oh, yes, that would have done it. If you’re behind NAT (e.g. a router) then using
would not have worked because Apache doesn’t know what its external IP is. You’d need to use your NAT-ted IP address, e.g. 192.168/16 or 10/8, or default or *.
I probably should have picked up on that earlier, sorry.
I did not know this, this is true for only HHTPS then, because I could acces my website from anywhere using the http version whereas my public ip was stated in the virtual hosts file, which is strange. But anyway it sorted out now. Thanks for the effort for helping me, its appreciated!
