HTTPs is not working
I am not able to access https://salve.derwingx.com, also the redirection is not working from http to https.
sudo certbot --apache
  • Congratulations! Yourcom/fullchain.pem
    /etc/letsencrypt/live/s.com/privkey.pem
    Your cert will expire on 2020-04-08. To obtain a new or tweaked
    with the “certonly” option. To non-interactively renew all of
    your certificates, run “certbot renew”
Apache2
Ubuntu 19.04
no
certbot 0.31.0
My bad! Found the issue. ! I messed up the port.
Thanks for reporting back with the solution. Glad to hear you’re all set now! :tada:
