Https not working after successful certbot installation
www.helgabox.duckdns.org
sudo certbot --apache
Congratulations! You have successfully enabled https://helgabox.duckdns.org
https://www.ssllabs.com/ssltest/analyze.html?d=helgabox.duckdns.org
    /etc/letsencrypt/live/helgabox.duckdns.org/fullchain.pem
    /etc/letsencrypt/live/helgabox.duckdns.org/privkey.pem
    Your cert will expire on 2019-03-19. To obtain a new or tweaked
    with the “certonly” option. To non-interactively renew all of
    your certificates, run “certbot renew”
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
Server version: Apache/2.4.18 (Ubuntu)
Server built: 2018-06-07T19:43:03
Ubuntu Server 16.04
no
Thanks in andvance for your help!
Hi @calgara12,
This looks like a firewall problem, where a host or network firewall isn’t permitting connections on port 443. Can you check that there is no firewall rule anywhere that would block this? (If you’ve set up a router to forward port 80 to some device, you’d also have to set it up to forward port 443 in a similar way.)
Thank you so much. I forgot to forward the port 443.
Hi @calgara12
now your https server works. But you have only a certificate with one domain name:
CN=helgabox.duckdns.org
19.12.2018
19.03.2019
helgabox.duckdns.org - 1 entry
So your www-version doesn't work.
  • Remove the www - dns entry or
  • Create a new certificate with both domain names - non-www and www
