Https not working after issuing a certificate
klima3000.ch
apache 2.4.29
Ubuntu server 18.04
Yes
No
Hello all
When I issue a new certificate my website is not running under https://klima3000.ch
https://letsdebug.net/klima3000.ch/2598 did say that everithing looks fine.
What could be the problem?
Thank you for your answer in advance!
Could you answer those questions?
Is Apache configured to use the certificate?
Is there a firewall blocking access to port 443?
Hi mnordhoff
Yes
Could it be that I have to forward that port on my router?
Maybe. Did you have to forward port 80?
http://klima3000.ch/ works.
https://klima3000.ch/ times out.
There's some configuration difference between them -- firewalls, port forwarding, maybe both.
thank you mnordhoff
will try to forward port 443
It was the port forward!
Thank you very very much mnordhoff
