xdmister.eu
certbot -appache
Succesfuly you ahve certificate or something like this
apache2
ubuntu
my own
no
certbot 1.13.0
Also note that there is no redirect from HTTP to HTTPS. The command you ran should have tried to apply that redirect (if you choose to), but your Apache configuration might have prevented that. However, without the full output of your certbot command, we can't know what happened. You can check the log in /var/log/letsencrypt/.
And please don't generate any further certificates. You've managed to issue TEN certificates since March 7th! If you succesfully issued a certificate, but you don't have HTTPS, the problem is not with the issuing, but with something else. Therefore, re-issuing certificates is not helpful and is only contributing to the ever growing load on the Let's Encrypt systems. Please see the certbot documentation for all certbot options, such as certbot install.
The insecure content of which @Rip speaks is also known as "mixed content". You can use a tool like Missing Padlock to help identify other instances of "mixed content".
