Running certbot did not give me https
My domain is: http://www.newkiddintown.com/
I ran the commands on this site https://certbot.eff.org/lets-encrypt/debianbuster-apache with no errors.
All codes succeeded but my website is still not https.
The operating system my web server runs on a raspberry pi with Buster.
My hosting provider is: google domains
I can login to a root shell on my machine (yes)
Dry run works and says it was successful.
The only thing i can think of for why it isnt working is when it asked for the domain, i put in newkiddintown.com instead of www.newkiddintown.com
Not sure if that will affect it, but let me know how to change that if so.
Welcome to the Let's Encrypt Community, Garrett :slightly_smiling_face:
Your certificate needs to cover both newkiddintown.com and www.newkiddintown.com.
Certificate History
Could you please guide me on how to add the new domain to the existing cert?
You can't. You have to generate a new certificate.
Use -d "newkiddintown.com,www.newkiddintown.com" in your certbot command.
Here is what has happened once following your instructions
pi@raspberrypi:~ $ sudo certbot --apache -d "newkiddintown.com,www.newkiddintown.com"
requested (ref: /etc/letsencrypt/renewal/newkiddintown.com.conf)
It contains these names: newkiddintown.com
You requested these names for the new certificate: newkiddintown.com,
certificate?
(E)xpand/(C)ancel: E
Renewing an existing certificate for newkiddintown.com and www.newkiddintown.com
http-01 challenge for www.newkiddintown.com
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/000-default-le-ssl.conf
We were unable to find a vhost with a ServerName or Address of www.newkiddintown.com.
Which virtual host would you like to choose?
1: 000-default-le-ssl.conf | newkiddintown.com | HTTPS | Enabled
2: 000-default.conf | | | Enabled
Select the appropriate number [1-2] then [enter] (press 'c' to cancel):
Is selecting 1 the correct option here? Im not sure why there are two...
Thanks for your help so far, super helpful!
You need to specify ServerAlias www.newkiddintown.com in your apache vHost.
FYI, i selected 1 as the option there.
Here is what happened, the site is still not HTTPS.
1: newkiddintown.com
2: www.newkiddintown.com
blank to select all options shown (Enter 'c' to cancel): 1,2
Cert not yet due for renewal
What would you like to do?
2: Renew & replace the cert (may be subject to CA rate limits)
Enhancement redirect was already set.
You add it as a line right below the ServerName newkiddintown.com line in your 000-default.conf file.
By the way:
Your Apache configuration doesn't have a HTTP to HTTPS redirect set for the www subdomain.
Please show apachectl -S
Here is inside the 000-default
Is this the correct way to add the serveralias?
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =newkiddintown.com, www.newkiddintown.com
vim: syntax=apache ts=4 sw=4 sts=4 sr noet
Add these lines at the top:
then restart apache.
pi@raspberrypi:~ sudo apachectl -S AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message VirtualHost configuration: *:443 newkiddintown.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2) *:80 127.0.1.1 (/etc/apache2/sites-enabled/000-default.conf:1) ServerRoot: "/etc/apache2" Main DocumentRoot: "/var/www/html" Main ErrorLog: "/var/log/apache2/error.log" Mutex rewrite-map: using_defaults Mutex ssl-stapling-refresh: using_defaults Mutex ssl-stapling: using_defaults Mutex ssl-cache: using_defaults Mutex default: dir="/var/run/apache2/" mechanism=default Mutex watchdog-callback: using_defaults PidFile: "/var/run/apache2/apache2.pid" Define: DUMP_VHOSTS Define: DUMP_RUN_CFG User: name="www-data" id=33 Group: name="www-data" id=33 pi@raspberrypi:~
No, he doesn't:
osiris@erazer ~ $ curl -LI www.newkiddintown.com
HTTP/1.1 200 OK
Date: Tue, 05 Jan 2021 20:41:13 GMT
Server: Apache/2.4.38 (Raspbian)
Last-Modified: Tue, 05 Jan 2021 18:55:39 GMT
ETag: "5661-5b82bc0b57c8c"
Accept-Ranges: bytes
Content-Length: 22113
Vary: Accept-Encoding
Content-Type: text/html
osiris@erazer ~ $
No redirect at all for the www subdomain.
Oh really... are you sure... :wink:
It's malformed isn't it. :confused:
The fact there are a bunch of Rewrite rules supposed to make a redirect doesn't mean the webserver actually is redirecting.
That was to ask how to put it in there, is that not correct?
Not quite.
You need the lines I mentioned.
Certbot should add the redirects by itself.
You put the ServerName and ServerAlias directives at the place where in your current configuration file there is a commented ServerName. Don't forget to add the www. at the ServerAlias directive which was forgotten by @griffin earlier :wink: Using the same value for ServerName and ServerAlias isn't going to work.
You forgot to put the www....
