Running certbot did not give me https
Crap. Fixed. Thanks. :slightly_smiling_face:
Okay. Just so theres no confusion. Please edit how the 000-default should look.. that would be easiest for me to understand..
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =newkiddintown.com
vim: syntax=apache ts=4 sw=4 sts=4 sr noet
Scrap the rewrite.
Add the two lines right below the top comment block as @Osiris stated.
Let certbot create the correct rewrites afterwards.
So...
ServerName newkiddintown.com
ServerAlias www.newkiddintown.com
Delete this:
RewriteEngine on
Okay, this is done. Checking site.
<VirtualHost *:80>
# The ServerName directive sets the request scheme, hostname and port t$
    # modules, e.g.
I'm confused. Why did you duplicate the other two lines?
Rebooting now for site
they were already on there, ill delete them. youre talking about
correct?
<VirtualHost *:80>
    # modules, e.g.
I was trying to have you add the server lines ABOVE the existing two.
Apologies, this is fixed.
Now run certbot, install existing, and enable https
This is done. gave success site still doesnt show https when browsing to https://www.newkiddintown.com
here is what was done:
@raspberrypi:~ $ sudo certbot --apache
1: newkiddintown.com
2: www.newkiddintown.com
blank to select all options shown (Enter 'c' to cancel): 1,2
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/newkiddintown.com.conf)
What would you like to do?
2: Renew & replace the cert (may be subject to CA rate limits)
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/000-default-le-ssl.conf
Redirecting vhost in /etc/apache2/sites-enabled/000-default.conf to ssl vhost in /etc/apache2/sites-enabled/000-default-le-ssl.conf
Congratulations! You have successfully enabled https://newkiddintown.com and
Nevermind! Seems to be working. Amazing work.
Looking good!
:partying_face:
Are you able to load up https://www.newkiddintown.com/ correctly?
Odd issue, i can only seem to load it up on IOS devices.
Loads great to me. :slightly_smiling_face:
I'm using an Android.
Well alright then! Sounds good to me. Must be something on the google domains side. Thanks for all your help!
You picked the better solution @garrett_kidd.
:grin:
Only odd thing is, I cannot access the website internally, only externally. Domain.google.com shows i have 4 certs. Any ideas why this site is now only accessible when im not on the same network as the device holding the website? I might need to start a new topic, lmk if i do.
Two of them are precertificates. You'll see all your Let's Encrypt certificates listed in pairs this way.
Look here (no precertificates):
Versus here (precertificates):
