My domain is: http://www.newkiddintown.com/
The operating system my web server runs on a raspberry pi with Buster.
My hosting provider is: google domains
I can login to a root shell on my machine (yes)
I ran the commands on this site https://certbot.eff.org/lets-encrypt/debianbuster-apache with errors
I had previously been successful in setting the website up with no errors in running cert commands. I have moved to a different house, same IP address, and still have port forwarding over port 80 enabled.
Attempting to access the site, it does not work unless internally.
Im assumed that the Cert for the site was needing to be renewed, when used the command
sudo certbot renew
I received this error
http-01 challenge for newkiddintown.com
http-01 challenge for www.newkiddintown.com
Challenge failed for domain newkiddintown.com
Failed to renew certificate www.newkiddintown.com with error: Some challenges have failed.
/etc/letsencrypt/live/www.newkiddintown.com/fullchain.pem (failure)
MPORTANT NOTES:
Domain: newkiddintown.com
Type: connection
Detail: Fetching
http://newkiddintown.com/.well-known/acme-challenge/eQ7Pq7QFp_vLFGoIWjyQJcrTaMq6xYj-1knV_a7nYgA:
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
that you are serving files from the webroot path you provided"
I have double check that the raspberry pi is port forwarded through my router via port 80.
What are some next step troubleshooting i can do here?
The device can ping 8.8.8.8 as well as the gateway.
The website is reachable by public IP address via port 80.
Let me know.
