After trying to install with ./letsencrypt-auto, I’ve decided to go back to http for now, since I:
Couldn’t get letsencrypt working easily due to a bug with WSGI applications
Don’t care enough to try harder, since my site is pretty low in traffic
I tried to do this by deleting the directories mentioned here . I also ran a sudo a2dissite for each conf file with le-ssl in the name.
Now, when I visit my site, Safari and Chrome both still try to use https, and fail with messages like “This site can’t provide a secure connection.”
How can I completely revert back to http, having already deleted directories before I read about the rollback option?
jsha
April 9, 2016, 12:29am
2
Can you provide your site address so we can check it out? It sounds like you may have a redirect still configured in your Apache config.
Sure, it’s at http://deentaylor.com/ . It’s supposed to redirect to http://luke.deentaylor.com/ (which works fine over HTTP)
I have already removed the RewrtiteRules from the bottom of my apache cons files.
It appears that it works when clicking on the link, but if I put deentaylor.com into Safari, it tries to access a https version of the site. Now it seems to me like this is just an issue with browser caching. Sorry for the inconvenience.
jsha
April 9, 2016, 1:40am
5
No problem! Glad it worked out.
