Renewing not working [SOLVED]
My domain is: nc.celebrate.de
I ran this command: certbot renew --dry-run
It produced this output: connection refused
My web server is (include version): Apache 2.4.6
The operating system my web server runs on is (include version): CentOS 7.6.1810
My hosting provider, if applicable, is: me
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.36.0
The let’s encrypt debug log - sorry can’t upload as a new user - is available here:
https://nc.celebrate.de/log.txt
Thanks for helping.
Frank
Hi @digidax
there
is your answer: You need a working port 80. But your port 80 doesn't answer - https://check-your-website.server-daten.de/?q=nc.celebrate.de
http://nc.celebrate.de/
94.100.75.11 -2 1.080 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it 94.100.75.11:80
94.100.75.11 200 3.480 A
http://nc.celebrate.de/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
94.100.75.11 -2 1.090 V
Looks like a blocking firewall. Is there a running webserver? Is port 80 open?
Yes port 80 is open:
-bash-4.2# netstat -tulpn | grep 80
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 30661/httpd
The logfile you have downloaded (https://nc.celebrate.de/log.txt) is on the same machine which has this renew problem:
-bash-4.2# ls -l /var/www/html/
total 36
-rw-r–r-- 1 apache apache 23695 Sep 4 15:07 log.txt
So you could download the logfile, port 80 and 443 are open and the webserver is working.
That’s the stupid thing I can’t figure out what the problem is.
Thanks for helping
I can't download the http version. https works, but http is blocked.
It looks like a firewall. Or is it a home server with a wrong port forwarding?
You’re right, there is a problem with the firewall (pf sense) but I don’t know what because the configuration is ok. Port 80 is open from inside the DMZ Subnet (checked with telnet open IP:80 and http is working but not from public net) I will check it and come back. Thanks.
Problem found:
There was a bug in PfSense, the GUI shows a correct NAT setup but in the kernel filter only the dest nat rule was set, the correspondentin forwarding rule to port 80 was missing. After update pfsense to the last stable and re setup the rule, the dry-run was successful.
thanks jürgen for your hint and best regards,
Frank
