Certbot renew error while using the renew command-connection refused
Hi
My domain is:exrcloud.exr.ca
I ran this command:sudo certbot renew --dry-run
Domain: exrcloud.exr.ca
Type: connection
Detail: Fetching
http://exrcloud.exr.ca/.well-known/acme-challenge/R8UNO4VtBW7Ju9Nv_trm6GeLgVizw8HviOhwbiFuX1Q:
Connection refused
My web server is (include version):Apache2
The operating system my web server runs on is (include version):Ubuntu 18
Please help
I tried to renew the cert using the command but it gives me error regarding connection refused.
it worked the last time when i created the new certificate 2 months ago
Hi @nmacwan
looks like a firewall or another blocking instance.
Works http internal?
What says
curl http://exrcloud.exr.ca/.well-known/acme-challenge/1234
What's the server software you use? apachectl -S or nginx -T?
Yes it works internally.
What says
but since the configuration is set to redirect http to https it directly goes to https://exrcloud.exr.ca
What’s the server software you use? apachectl -S or nginx -T?
we uses apachectl
WE have set the port for https to 4445 so that it can be accessed outside
since 443 is already being used
but i dont think this might create any issue.
Since when i created the cert the port and redirect was already setup before the cert registration
Your port 80 must answer.
You can redirect to port 443 (extern), but port 80 refused -> renew doesn’t work.
What should i change for 80 to Answer??
Port 80 is set to listen in Apache and is not blocked either.
It is blocked:
There is no answer. If if works internal, you have a blocking instance.
A http status 404 - Not Found or a redirect is expected.
The Above link when opened internally
redirects to the following link
https://exrcloud.exr.ca/
This is the whole error i am getting:
Processing /etc/letsencrypt/renewal/exrcloud.exr.ca-0001.conf
http-01 challenge for exrcloud.exr.ca
Waiting for verification…
Attempting to renew cert (exrcloud.exr.ca-0001) from /etc/letsencrypt/renewal/exrcloud.exr.ca-0001.conf produced an unexpected error: Failed authorization procedure. exrcloud.exr.ca (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://exrcloud.exr.ca/.well-known/acme-challenge/zSpg6MQIzm-4Wbl2XnC79cFiu1cJbPI0szYJPU7fgnY: Connection refused. Skipping.
/etc/letsencrypt/live/exrcloud.exr.ca-0001/fullchain.pem (failure)
    Type: connection
    Detail: Fetching
    Connection refused
I hope this my help
That's not relevant, if an extern check doesn't work. Checking your domain online via https://check-your-website.server-daten.de/?q=exrcloud.exr.ca there is no answer.
So Letsencrypt can't connect your domain and can't validate the domain name -> no certificate.
If it works internal, it's not a problem of your Apache. It's a blocking instance. Or a wrong port forward.
Thanks ,
i tried to solve the port 80 for connection refuse.
the following command works fine now.
sudo certbot renew --dry-run(no errors and runs successful)
but when i try to run the actual renew command it gives me the following error.
Attempting to renew cert (exrcloud.exr.ca-0001) from /etc/letsencrypt/renewal/exrcloud.exr.ca-0001.conf produced an unexpected error: urn:ietf:params:acme:error:rateLimited :: There were too many requests of a given type :: Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/. Skipping.
