Connection refused during renew
Good morning, I have been using certbot for a long time, since the last renewal (without remembering having made any changes) I receive this error:
Fetching http://corosspp.ns0.it/.well-known/acme-challenge/9vuC-1uadahs_aBG0q5zJv0o9STU3HwrIi65G2wlkQI: Connection refused
my domains are:
wolverine.ns0.it
corosspp.ns0.it
ufficiosonoro.ns0.it
certbot version: 1.21.0
Operating system Ubuntu 22.04
web Server Apache 2.4.52-1ubuntu4.6
for debugging I used the command:
/usr/bin/certbot certanly --webroot --agree-tos --redirect --hsts --staple-ocsp -d corosspp.ns0.it -w /var/www/html -v --dry-run -- debug-challenges -v
when the script stopped for debugging I checked that the challenge was in the right directory and I also tried to reach it from the outside with a browser. I can't figure out what the problem is.
This is the execution log:
root@Wolverine:/var/www/html# sudo /usr/bin/certbot certonly --webroot --agree-tos --redirect --hsts --staple-ocsp -d corosspp.ns0.it -w /var/www/html -v --dry-run --debug-challenges -v
Root logging level set at 10
Requested authenticator webroot and installer None
Single candidate plugin: * webroot
Description: Place files in webroot directory
Interfaces: Authenticator, Plugin
Entry point: webroot = certbot._internal.plugins.webroot:Authenticator
Initialized: <certbot._internal.plugins.webroot.Authenticator object at 0x7f5f23732920>
Prep: True
Selected authenticator <certbot._internal.plugins.webroot.Authenticator object at 0x7f5f23732920> and installer None
Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-staging-v02.api.letsencrypt.org/acme/acct/124630394', new_authzr_uri=None, terms_of_service=None), 3fd0afe9e1966c559db5607307f4e177, Meta(creation_dt=datetime.datetime(2023, 11, 7, 16, 53, 32, tzinfo=<UTC>), creation_host='net-2-34-41-241.cust.vodafonedsl.it', register_to_eff=None))>
Sending GET request to https://acme-staging-v02.api.letsencrypt.org/directory.
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org:443
https://acme-staging-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 826
Received response:
HTTP 200
Server: nginx
Date: Wed, 08 Nov 2023 17:05:02 GMT
Content-Length: 826
X-Frame-Options: DENY
  "VyHbqbTbuY4": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
  "keyChange": "https://acme-staging-v02.api.letsencrypt.org/acme/key-change",
  "meta": {
    "caaIdentities": [
      "letsencrypt.org"
    "termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.3-September-21-2022.pdf",
    "website": "https://letsencrypt.org/docs/staging-environment/"
  "newAccount": "https://acme-staging-v02.api.letsencrypt.org/acme/new-acct",
  "newNonce": "https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce",
  "newOrder": "https://acme-staging-v02.api.letsencrypt.org/acme/new-order",
  "renewalInfo": "https://acme-staging-v02.api.letsencrypt.org/draft-ietf-acme-ari-01/renewalInfo/",
  "revokeCert": "https://acme-staging-v02.api.letsencrypt.org/acme/revoke-cert"
Notifying user: Simulating a certificate request for corosspp.ns0.it
Requesting fresh nonce
Sending HEAD request to https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce.
https://acme-staging-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
Received response:
HTTP 200
Server: nginx
Link: <https://acme-staging-v02.api.letsencrypt.org/directory>;rel="index"
Replay-Nonce: pj0iHUyqlPD83fuSXfkJuFTLHjl_B-6Ev73bwV19MCg8GF7Fs7w
Storing nonce: pj0iHUyqlPD83fuSXfkJuFTLHjl_B-6Ev73bwV19MCg8GF7Fs7w
JWS payload:
b'{\n  "identifiers": [\n    {\n      "type": "dns",\n      "value": "corosspp.ns0.it"\n    }\n  ]\n}'
Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/new-order:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xMjQ2MzAzOTQiLCAibm9uY2UiOiAicGowaUhVeXFsUEQ4M2Z1U1hma0p1RlRMSGpsX0ItNkV2NzNid1YxOU1DZzhHRjdGczd3IiwgInVybCI6ICJodHRwczovL2FjbWUtc3RhZ2luZy12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL25ldy1vcmRlciJ9",
  "signature": "oN8xF62NvYtT-v1uCVvWfmPHbkJq1nBBuGCweVpxdYK-YoT7muqptt5yFWyZGxCRPDkM0jJriGoW-XuKbBWjHTNInHTrH45DEmZiLUfiajIcirTipgBHeJR-So-26XlPs9PUlLhHUqBssZuTPset8pPrjgxbx8KQtWlikjCwgOgAntzwbe9ZOOTfQO7ONtRViZ_eS27TDjfvw05LU0WpHVJhz0RL-Q02uSqBmJbEWORfTkvrzeVKQys4F1ZMl1s5v-SgpZXhh4sqWlhYAYhPzUw2cwCgBjwaDkioodmgMd39u4tf3o6LDs8fejTWst5BobpGf2yPZ9EUe8ecquF6Ig",
  "payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogImNvcm9zc3BwLm5zMC5pdCIKICAgIH0KICBdCn0"
https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 353
Received response:
HTTP 201
Server: nginx
Content-Length: 353
Boulder-Requester: 124630394
Location: https://acme-staging-v02.api.letsencrypt.org/acme/order/124630394/12127299454
Replay-Nonce: lM2tIvPpUfNqc7BYM09AyC-dN66YbaTNKozYcRse-KXwdAdTad0
  "status": "pending",
  "expires": "2023-11-15T17:05:02Z",
  "identifiers": [
      "type": "dns",
  "authorizations": [
    "https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/9347179834"
  "finalize": "https://acme-staging-v02.api.letsencrypt.org/acme/finalize/124630394/12127299454"
Storing nonce: lM2tIvPpUfNqc7BYM09AyC-dN66YbaTNKozYcRse-KXwdAdTad0
JWS payload:
b''
Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/9347179834:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xMjQ2MzAzOTQiLCAibm9uY2UiOiAibE0ydEl2UHBVZk5xYzdCWU0wOUF5Qy1kTjY2WWJhVE5Lb3pZY1JzZS1LWHdkQWRUYWQwIiwgInVybCI6ICJodHRwczovL2FjbWUtc3RhZ2luZy12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzkzNDcxNzk4MzQifQ",
  "signature": "At-0cpqjXh9R-6jKYN0vxfgAkka_FFiDXHot8Py66UF5d4kkFEnrV6Wx8cvG8HFK8TQebxY38N2Zqux8vbpCBnKU4Ynce6QB8t9lKoLFUYQETnnUT9MYkTeHBSwhH7GBYB7iHd2QGgpjK7eesH-4PytCNeOzElZW7wkuDhBneY8ZdS5H8mkjaKfswbonw2Iw2QXzkaYuZWOX_nVCz8YPOIRZZAvaNPB8jMqRZt8fsie3uI-cYwovcdTq9-zjvc_gsQha2QigPdxP3PDj0tUaUGssopeEvKfUDFY4VtRIellVgvigMGMBuRTmoSU88ETf9mFcxrh9-6cnaTjuj2011g",
  "payload": ""
https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/9347179834 HTTP/1.1" 200 817
Received response:
HTTP 200
Server: nginx
Content-Length: 817
Replay-Nonce: lM2tIvPpzSkz_ZHu-mKzyRnYO1S_ivuwZvpfB2C1g5eKdKfRYFo
  "identifier": {
    "type": "dns",
  "challenges": [
      "type": "http-01",
      "url": "https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/9347179834/aVc4sQ",
      "token": "9vuC-1uadahs_aBG0q5zJv0o9STU3HwrIi65G2wlkQI"
      "type": "dns-01",
      "url": "https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/9347179834/kF2LDA",
      "type": "tls-alpn-01",
      "url": "https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/9347179834/hEbn9w",
Storing nonce: lM2tIvPpzSkz_ZHu-mKzyRnYO1S_ivuwZvpfB2C1g5eKdKfRYFo
http-01 challenge for corosspp.ns0.it
Using the webroot path /var/www/html for all unmatched domains.
Creating root challenges validation dir at /var/www/html/.well-known/acme-challenge
Attempting to save validation to /var/www/html/.well-known/acme-challenge/9vuC-1uadahs_aBG0q5zJv0o9STU3HwrIi65G2wlkQI
Notifying user: Challenges loaded. Press continue to submit to CA. Pass "-v" for more info about
challenges.
challenges.
Press Enter to Continue
JWS payload:
b'{}'
Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/9347179834/aVc4sQ:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xMjQ2MzAzOTQiLCAibm9uY2UiOiAibE0ydEl2UHB6U2t6X1pIdS1tS3p5Um5ZTzFTX2l2dXdadnBmQjJDMWc1ZUtkS2ZSWUZvIiwgInVybCI6ICJodHRwczovL2FjbWUtc3RhZ2luZy12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2NoYWxsLXYzLzkzNDcxNzk4MzQvYVZjNHNRIn0",
  "signature": "DVVCHgtQcFxX8m6tFEgZsg8eT7oeI4BCX-swLzydbwnGJ7dNLnb3SMWaJcX-sRI2PDeSh0gAunsscVOrE6cGiWl2EdQPdESMPUnGWIQYjyK853PLbFkm-_8eLaYZA5owBdKu0XHMVZYzKBfcOQIR6rQGH3BYHzDgBcnvGxneyy-G3tLmPPwe-I9oJ2n8re_A4qJ69UMYmtPQh2k76NJc0QLs1ghH-0fP_XliidzC1JAo8nA_wJbgYyuONnFAsSqiKR8ubdCqom0aX0OhOZ46uOK5iA0jaDRocC65lV81Y-aVXpjackZNwhkMH5C19Q0BwTFbKlm_BFo0H33mOwxTKw",
  "payload": "e30"
https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/chall-v3/9347179834/aVc4sQ HTTP/1.1" 200 193
Received response:
HTTP 200
Server: nginx
Date: Wed, 08 Nov 2023 17:05:04 GMT
Content-Length: 193
Link: <https://acme-staging-v02.api.letsencrypt.org/directory>;rel="index", <https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/9347179834>;rel="up"
Location: https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/9347179834/aVc4sQ
Replay-Nonce: lM2tIvPpTErbIkm7svxuO9c8DBS_AbnTdXXpFLIZ_HVb6wcL4ZI
  "type": "http-01",
Storing nonce: lM2tIvPpTErbIkm7svxuO9c8DBS_AbnTdXXpFLIZ_HVb6wcL4ZI
JWS payload:
b''
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xMjQ2MzAzOTQiLCAibm9uY2UiOiAibE0ydEl2UHBURXJiSWttN3N2eHVPOWM4REJTX0FiblRkWFhwRkxJWl9IVmI2d2NMNFpJIiwgInVybCI6ICJodHRwczovL2FjbWUtc3RhZ2luZy12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzkzNDcxNzk4MzQifQ",
  "signature": "iCvA3NOFbY_1PK7AuKUz_qsOCL-x4S76cB67n1F2SE0UdoFfNR_lLTYNdMD0HeG-bx0OEH89gLWhVhWCTxz0pNUc6QXlBlaEiFdJM8M_slIQ77de8WYC2SBIHdST7_NiY81zhRAGzWXiKRX0Hch6kJp4LQ9p6R_F-3m_gl8TcwIugolf6JIfBSRKAVPgVriucb5ueYLZfoY2F55h7JvggQupHoHj8dN3E-tvMYNlkAAeQir_9TgcpHOdckh59Kr6w7P6-M65W7MibZubGXinjSqOlHwztMHkv6h7Ndu6IXn_nrRhTR7MY-cXe3LEaNbnl1i7KG-shqXu2enhJoaHHA",
  "payload": ""
https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/9347179834 HTTP/1.1" 200 1028
Received response:
HTTP 200
Server: nginx
Date: Wed, 08 Nov 2023 17:05:05 GMT
Content-Length: 1028
Replay-Nonce: pj0iHUyqbedvZLRAmUAW74USmOJTXnTyyexzN7CEsdgZXT073Lc
  "identifier": {
    "type": "dns",
  "status": "invalid",
  "challenges": [
      "type": "http-01",
      "error": {
        "type": "urn:ietf:params:acme:error:connection",
        "detail": "2.34.41.241: Fetching http://corosspp.ns0.it/.well-known/acme-challenge/9vuC-1uadahs_aBG0q5zJv0o9STU3HwrIi65G2wlkQI: Connection refused",
        "status": 400
      "token": "9vuC-1uadahs_aBG0q5zJv0o9STU3HwrIi65G2wlkQI",
      "validationRecord": [
          "url": "http://corosspp.ns0.it/.well-known/acme-challenge/9vuC-1uadahs_aBG0q5zJv0o9STU3HwrIi65G2wlkQI",
          "hostname": "corosspp.ns0.it",
          "port": "80",
          "addressesResolved": [
            "2.34.41.241"
          "addressUsed": "2.34.41.241"
      "validated": "2023-11-08T17:05:04Z"
Storing nonce: pj0iHUyqbedvZLRAmUAW74USmOJTXnTyyexzN7CEsdgZXT073Lc
Challenge failed for domain corosspp.ns0.it
Notifying user:
  Domain: corosspp.ns0.it
  Type:   connection
  Detail: 2.34.41.241: Fetching http://corosspp.ns0.it/.well-known/acme-challenge/9vuC-1uadahs_aBG0q5zJv0o9STU3HwrIi65G2wlkQI: Connection refused
  Type:   connection
Encountered exception:
  File "/usr/lib/python3/dist-packages/certbot/_internal/auth_handler.py", line 90, in handle_authorizations
  File "/usr/lib/python3/dist-packages/certbot/_internal/auth_handler.py", line 178, in _poll_authorizations
Calling registered functions
Removing /var/www/html/.well-known/acme-challenge/9vuC-1uadahs_aBG0q5zJv0o9STU3HwrIi65G2wlkQI
All challenges cleaned up
Exiting abnormally:
  File "/usr/bin/certbot", line 33, in <module>
    sys.exit(load_entry_point('certbot==1.21.0', 'console_scripts', 'certbot')())
  File "/usr/lib/python3/dist-packages/certbot/main.py", line 15, in main
  File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1574, in main
  File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1434, in certonly
    lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
  File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 133, in _get_and_save_cert
  File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 459, in obtain_and_enroll_certificate
  File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 389, in obtain_certificate
  File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 439, in _get_order_and_authorizations
Thanks in advance
Marco
Welcome to the community @marcobto58
Something is blocking HTTP requests to your Apache server. I can't even reach your "home" page.
If you can reach your Apache with HTTP on your local network then it might be your router or some firewall. The Let's Debug test site https://letsdebug.net is helpful to test after you make changes. Use that before trying to get more certs so you don't get blocked temporarily for too many failed requests (per hour).
I can reach you with HTTPS (port 443) but not HTTP (port 80)
curl -I https://corosspp.ns0.it
HTTP/1.1 200 OK
Date: Wed, 08 Nov 2023 17:24:43 GMT
Server: Apache/2.4.52 (Ubuntu)
curl -I http://corosspp.ns0.it
curl: (7) Failed to connect to corosspp.ns0.it port 80 after 101 ms: Connection refused
The error message detail line says it all:
The HTTP connection was refused.
while you do have opended port 443, http-01 challange only starts from port 80
Demonstrating what @MikeMcQ, @rg305 and @orangepizza have all stated above.
$ nmap -Pn -p80,443 wolverine.ns0.it
Starting Nmap 7.80 ( https://nmap.org ) at 2023-11-08 18:17 PST
Nmap scan report for wolverine.ns0.it (2.34.41.241)
Host is up (0.19s latency).
rDNS record for 2.34.41.241: net-2-34-41-241.cust.vodafonedsl.it
PORT    STATE  SERVICE
80/tcp  closed http
443/tcp open   https
Nmap done: 1 IP address (1 host up) scanned in 1.93 seconds
$ nmap -Pn -p80,443 corosspp.ns0.it
Nmap scan report for corosspp.ns0.it (2.34.41.241)
Host is up (0.26s latency).
PORT    STATE  SERVICE
80/tcp  closed http
443/tcp open   https
Nmap done: 1 IP address (1 host up) scanned in 1.17 seconds
$ nmap -Pn -p80,443 ufficiosonoro.ns0.it
Failed to resolve "ufficiosonoro.ns0.it".
WARNING: No targets were specified, so 0 hosts scanned.
Nmap done: 0 IP addresses (0 hosts up) scanned in 2.43 seconds
