Renewal failed with "connection refused" [solved]
Hi, I have been unable to renew my SSL certificate for a domain with currently perfectly working https connection. Let's debug says the site is fine using http-01 or dns-01. I also temporary stopped fail2ban before running certbot renewal command. I haven't changed the Apache configuration file or .htaccess file since the last time I renewed the certificate with success, I don't see any possible firewall aside from fail2ban (that I stopped temporarily for the sake of renewal), so my case seems to be different from the ones that I found in this forum (sorry if I have overlooked something, but there are so many of these...).
Thank you very much in advance.
My domain is:paccoud.booqinez.com
Processing
Processing /etc/letsencrypt/renecertbot 2.6.0certbot 2.6.0wal/paccoud.booqinez.com.conf
Renewing an existing certificate for paccoud.booqinez.com and olivierpaccoud.booqinez.com
  Domain: olivierpaccoud.booqinez.com
  Type:   connection
  Detail: 82.64.132.53: Fetching http://olivierpaccoud.booqinez.com/.well-known/acme-challenge/E1SKGbQDspSbyiWbOBO5l2Ycn2fhAOebdPIcHPqkPRI: Connection refused
  Domain: paccoud.booqinez.com
  Type:   connection
  Detail: 82.64.132.53: Fetching http://paccoud.booqinez.com/.well-known/acme-challenge/TFzJ5nDZT9CgsV1G8rofE8yomOWktzV4jCjeZDAcQ80: Connection refused
Failed to renew certificate paccoud.booqinez.com with error: Some challenges have failed.
  /etc/letsencrypt/live/paccoud.booqinez.com/fullchain.pem (failure)
apache-2.4.57-1
Arch Linux (up to date)
My hosting provider, if applicable, is: I am hosting myself
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.6.0
The "Connection refused" error message suggests your Apache wasn't running at the time of the renewal attempt. Which is weird, as you're using the apache authenticator, which, I believe, should try to start Apache when it wasn't running before..?
Currently I see a perfectly fine Apache on HTTP port 80. If you try to renew again, do you still get the "Connection refused" error or a different one?
Apache is/was/has been running each time I tried to renew... It is listening both on port 80 and 443
Anyhow, I tried again with
 certbot -d paccoud.booqinez.com --dry-run -v certonly
Which gave me
1: Apache Web Server plugin (apache)
2: Runs an HTTP server locally which serves the necessary validation files under
the /.well-known/acme-challenge/ request path. Suitable if there is no HTTP
server already running. HTTP challenge only (wildcards not supported).
(standalone)
3: Saves the necessary validation files to a .well-known/acme-challenge/
directory within the nominated webroot path. A seperate HTTP server must be
running and serving files from the webroot path. HTTP challenge only (wildcards
not supported). (webroot)
Select the appropriate number [1-3] then [enter] (press 'c' to cancel): 1
Simulating a certificate request for paccoud.booqinez.com
http-01 challenge for paccoud.booqinez.com
Challenge failed for domain paccoud.booqinez.com
  Type:   connection
  Detail: 82.64.132.53: Fetching http://paccoud.booqinez.com/.well-known/acme-challenge/pPC7Meg93NheaE1g8pj2HI38Ajj-_LyD_B4g4bamO2w: Connection reset by peer
So this time I got "connection reset by peer" instead of "connection refused", although I made no change on my side. Would this mean anything useful?
By the way, Appache log shows no entering connection...
I have no clue.. I can reach your site perfectly and LetsDebug at Let's Debug also doesn't show any issues..?
Perhaps you could try the webroot plugin? (Option 3 in the list you saw earlier, or use --webroot in combination with -w followed by the document root on the command line; see User Guide — Certbot 2.6.0 documentation for more information about the webroot authenticator plugin.)
Note that the current certificate contains the hostnames olivierpaccoud.booqinez.com and paccoud.booqinez.com, but with your latest command you only selected the latter hostname using the -d option. I'd recommend to include both hostnames in your next attempts. See the webroot documenation above on how to specify multiple webroots for multiple hostnames, if necessary.
It turned out reinsalling libxml2 solved the problem (I had Init: Session Cache is not configured [hint: SSLSessionCache] in apache error log). Thank you very much anyway.
