My domain is: www.hokyi.com
Processing /etc/letsencrypt/renewal/hokyi.com.conf
Cert is due for renewal, auto-renewingâŚ
Running pre-hook command: service nginx stop
http-01 challenge for hokyi.com
http-01 challenge for www.hokyi.com
Waiting for verificationâŚ
Attempting to renew cert (hokyi.com) from /etc/letsencrypt/renewal/hokyi.com.conf produced an unexpected error: Failed authorization procedure. hokyi.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://hokyi.com/.well-known/acme-challenge/SesNzbgXopmtehsMx8pKQp9Oe1lvDWhvvys1A41Cc0A: Connection refused, www.hokyi.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.hokyi.com/.well-known/acme-challenge/06oPiJFwN5zEcsJgcETb-4Za4bFNKmBAS72OWUw5fJo: Connection refused. Skipping.
/etc/letsencrypt/live/hokyi.com/fullchain.pem (failure)
Running post-hook command: service nginx start
Domain: hokyi.com
Type: connection
Detail: Fetching
Connection refusedDomain: www.hokyi.com
Type: connection
Detail: Fetching
Connection refusedTo fix these errors, please make sure that your domain name was
client. If youâre using the webroot plugin, you should also verify
nginx -v
nginx version: nginx/1.10.3 (Ubuntu)
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.6 LTS
Release: 16.04
Codename: xenial
I can login to a root shell on my machine (yes or no, or I donât know): yes
Iâm using a control panel to manage my site (no, or provide the name and version of the control panel): no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if youâre using Certbot): certbot 0.31.0
dry-run works fine:
certbot renew --dry-run
new certificate deployed without reload, fullchain is
** DRY RUN: simulating âcertbot renewâ close to cert expiry
/etc/letsencrypt/live/hokyi.com/fullchain.pem (success)
A file placed in webroot (/var/www/html/ttt) can be retrieved:
https://hokyi.com/.well-known/acme-challenge/ttt
